  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
Hello Chippy
                       It all depends on what you want the machine for!
I have an earlier version of this one that I got at a good price!(it is not a direct drive it has a high and low range gearbox)
http://www.toolco.co.uk/products/vm32b-belt-drive-variable-speed-milling-machine-1
It is ok  but it is not like having a proper milling machine!
They are ok on Aluminium and Brass etc but on steel of quality you have to take small cuts which is slow work but as a hobby machine it is ok
I have made a lot of parts and modified lots of parts (I like to be in charge of my own jobs!)
Keep your eye open for a used one with tooling(that's were you will spend a lot of money) probably as much as the machine because cheap tools are cheap tools!!!!
7 hours ago, rogerguzzi said:
Hello Chippy
Cheers Roger, I know anything at the sort of price im looking at will be a compramise and definitely agree second hand with tooling is the way to go. A bridgeport would be nice but its got to be carried down my long garden.
Steve
I have a Varco WM18 milling machine, I agree with Roger small milling machines are ok for ali plastic but struggle with decent steel, but I do use it a lot.
Makes a very accurate drill press and if you put router tools can be used for wood as well!
Would be nice to have a bigger one (or a CNC machine) but don't have the space in the workshop/garage.
I have put digital readouts on it well worth the extra money.
Mike
               I also fitted DRO on mine(I took a chance and ordered it direct from China)a lot cheaper and works for me as I am old school(Imperial!)plus it does things that are way above my pay scale!
Chippy if your budget will stretch to it go for the WM18 size in which ever make is cheapest because as Mike says they are not that strong!
I took mine to pieces to put it on the stand and give all the bits a good clean and lube(B****y Heavy!)
This is what I would really like! and so cheap even allowing for a new motor(well perhaps a touch smaller?)
https://www.ebay.co.uk/itm/Elliot-Omnimill-02-Milling-Machine-Lathe-Mill-Vertical-Horizontal-Turret/333289062330?hash=item4d99937fba:g:2eUAAOSwyElc1SY8
ps you will start making things you did not know you needed and doing ridiculas things because you can and spend hours making or modifying a part that is worth pence!!!!
Been wanting a sieg x2 for a while, just can't justify it to myself.
I've got a Sieg lathe from Arc Euro Trade, its a very good bit of kit and Arc have been brilliant for support.
The same thing happened when i got my myford lathe, i use it all the time now.
Yes Arc come highly recommend, its annoying because ive seen some serious mills for similar money but its just moving them (it has to go through the garage and down my garden into the workshop) its not doable on a pallet truck.
Hello Chippy
                       You can take them to pieces (still heavy but with a truss moveable!)
I have a myford as well but its ok for small jobs but it can not face a Spitfire Flywheel like my old big one can!
The only advise I would give is buy the biggest you can afford and accommodate
Jobs that are difficult on small machines are easy on big ones (I can skim the drum on a 19" motorcycle wheel on my big lathe!) 1950,s built
Ah but Its the usual problem though, buy a small one, its not big enough to do a brake disk, buy one to do a brake disk and its not big enough to do a flywheel and on and on.
My view is how often will you do large work vs. small work, i was always doing small work and once in a blue moon doing large work, so small works for me.
I've seen the sieg sx3 in action and it can definitely cut through steel and probably slower than a big beast, but as a novice i appreciate that,
sieg machines are rebranded all the time, keep checking ebay for mini mill...
Small machines are still useful and fun.
I have spent the last couple of days making a new gear lever knob. A bit different as it has RF transmitter in it to operate the OD so doesn't need the cable connection. Turner Ali body with a pespex window. Fun to make :)
Exactly, 99% of the time i will be tinkering with a bracket or a prototype part for a project. Once i have perfected the part i can send out to have it cnc copied.Any large turning i can farm out to a guy i use. Ive been looking at some great machines this week on ebay for small money but the logistics of getting them into my workshop is just not doable or put it another way i cant be arsed.
Very cool, i love it.
  • 1 month later...
Well I ended up getting a stand alone Rodney, Rodney did a bolt on mill attachment for the myford but they also did a few stand alone mills unusual in that the motor is in the base which is good for c of g. It makes it look a bit light on the top end but everything feels tight and the slide ways are excellent. I pick it up Saturday so can evaluate it more then.
Chippy,
Looks a very nice machine!     And your gallery of pics is a clever way of showing it - how did you do it?     AND, how yo make it work?   I can only scroll between the first two pics!
I think its a screen capture of the original pictures, I have tried scrolling thru the pics until I realised nothing was changing!
Still, nice machine and a decent DRO.
Mike
I can only support the views on the Sieg X3.
Have one since some years and you don´t know how you could work without a mill before.
I sure does look a cracking bit of kit Martin. I almost pulled the trigger on a new one. It would have been 2K with a bit of tooling and no stand. This old Rodney was £800 but i bet i could get that back and upgrade at a later date.
Well before I can report on the operation of this mill I am lowering the base by 5" as it was made for a tall bloke by the looks of things and giving it a lick of paint.. Also i can confirm its fu#$ing heavy but is now down my garden in the workshop.
