hardhatharry Posted March 18, 2020 Share Posted March 18, 2020 My fuel tank blanking vent disintegrated when I took the tank out and is no longer available. Is this just a bit of fuel pipe blanked off? Will aruldite do to blank some fuel pipe off as a substitute? Link to comment Share on other sites More sharing options...
zetecspit Posted March 18, 2020 Share Posted March 18, 2020 Not sure if replacements are available, and if they are what quality (ie hopefully last more than 6 months)But I would use a short length of r9 fuel hose, and push a short tight-fitting bolt in the end. Link to comment Share on other sites More sharing options...
hardhatharry Posted March 18, 2020 Author Share Posted March 18, 2020 Not available at Moss or Rimmers Link to comment Share on other sites More sharing options...
yorkshire_spam Posted March 18, 2020 Share Posted March 18, 2020 I had a similar problem back in 2014: I managed to find an appropriately sized blanking plug to replace it, but a short section of fuel hose with a bolt in would do just as well. The replacement was one of these I think: https://www.ebay.co.uk/itm/Silicone-Hose-End-Blanking-Caps-Plugs-Pipe-Finisher-Bung-Rubber-Any-Colour/293459867580?_trkparms=ispr%3D1&hash=item44539237bc:m:mD5dzqAxAY_UWXsGdWWOZgQ&enc=AQAEAAACUBPxNw%2BVj6nta7CKEs3N0qVbC0M4zY%2B4tZfgHyY9CJ6pCLE9eIp5ptYrLal52XkTEOX3AEw5jHgzpOHgPzVuH6SQxvD7ZiWCZ1W4YAwE4QjxpuH7RlPwVygeZ0oIMrMbini6EdXn9szue5fZ7oVr0fWGiQG0KzevKaw0BIiXdRG86PEPLognvJR201%2FyuyHWrcm%2BCFlPJRZrEBbSn9c3hfP8DyP0DA9hwozUyJq%2FTkRWoh3E19UVUDo9uE2O9Yw0HVYnhwnJ7J2E5GA4JSugrCUh8jBeVhj5i8Yl3iUOIQbUozyCWH7nKY%2BqmYCzVIeBvlQUPNKhRvQV3yBngYu1M5qZ0QmPkNRYqbv200mX2DA2qkAaQ32zEMTacUDvc8MLko8SV5aOIRPgQDVjPSZRhaYUua6NL3Wb1Ez8Ba3naPW9uYWZbYcujm5Idfe66oLh8ZogTVSUe2Mxezg0F3HydmtQCWhX85wQTxFpbpmnksSgwqASmjKDiPElWw%2BNGKna79u7XYyZN%2FM17CiAPxhTkDKtX73mQX6JtAfAe%2FP10DZCVUBoCQk1sNdghTS771GinE98nx72%2F00cVjQHUe1GO3vir0O7m6YXiYGimjE%2FctbOkjxdlamh%2F%2BgJam1veWbxTVTezuFQf0CqDxIncvVJ%2Bi7qzLOFi5q%2FkcrGpbmCMzXiXUfqRPeFhoaZ6mQ7AJF6AUJKJW6brrPsljpuFwbIEVerZQeLYR9jG34Q6NHYtKhgzyuHocv8DeiYO6IVCyHPLCbcfibDbPzU3BowS2aCyfQ%3D&checksum=293459867580b9c6c41a8cc14a40bf2250f09c1a2e51 Link to comment Share on other sites More sharing options...
zetecspit Posted March 19, 2020 Share Posted March 19, 2020 14 hours ago, yorkshire_spam said: I had a similar problem back in 2014: I managed to find an appropriately sized blanking plug to replace it, but a short section of fuel hose with a bolt in would do just as well. The replacement was one of these I think: https://www.ebay.co.uk/itm/Silicone-Hose-End-Blanking-Caps-Plugs-Pipe-Finisher-Bung-Rubber-Any-Colour/293459867580?_trkparms=ispr%3D1&hash=item44539237bc:m:mD5dzqAxAY_UWXsGdWWOZgQ&enc=AQAEAAACUBPxNw%2BVj6nta7CKEs3N0qVbC0M4zY%2B4tZfgHyY9CJ6pCLE9eIp5ptYrLal52XkTEOX3AEw5jHgzpOHgPzVuH6SQxvD7ZiWCZ1W4YAwE4QjxpuH7RlPwVygeZ0oIMrMbini6EdXn9szue5fZ7oVr0fWGiQG0KzevKaw0BIiXdRG86PEPLognvJR201%2FyuyHWrcm%2BCFlPJRZrEBbSn9c3hfP8DyP0DA9hwozUyJq%2FTkRWoh3E19UVUDo9uE2O9Yw0HVYnhwnJ7J2E5GA4JSugrCUh8jBeVhj5i8Yl3iUOIQbUozyCWH7nKY%2BqmYCzVIeBvlQUPNKhRvQV3yBngYu1M5qZ0QmPkNRYqbv200mX2DA2qkAaQ32zEMTacUDvc8MLko8SV5aOIRPgQDVjPSZRhaYUua6NL3Wb1Ez8Ba3naPW9uYWZbYcujm5Idfe66oLh8ZogTVSUe2Mxezg0F3HydmtQCWhX85wQTxFpbpmnksSgwqASmjKDiPElWw%2BNGKna79u7XYyZN%2FM17CiAPxhTkDKtX73mQX6JtAfAe%2FP10DZCVUBoCQk1sNdghTS771GinE98nx72%2F00cVjQHUe1GO3vir0O7m6YXiYGimjE%2FctbOkjxdlamh%2F%2BgJam1veWbxTVTezuFQf0CqDxIncvVJ%2Bi7qzLOFi5q%2FkcrGpbmCMzXiXUfqRPeFhoaZ6mQ7AJF6AUJKJW6brrPsljpuFwbIEVerZQeLYR9jG34Q6NHYtKhgzyuHocv8DeiYO6IVCyHPLCbcfibDbPzU3BowS2aCyfQ%3D&checksum=293459867580b9c6c41a8cc14a40bf2250f09c1a2e51 How's it lasting Sam? I ask as silicone doesn't like petrol and is fluro-lined (or should be) when exposed to petrol vapour. Certainly applies when using to connect throttle bodies to manifolds etc. (A friend lost a fuel pump after he stupidly fitted silicone hose between tank and pump on his newly acquired Cossie. We tried to clear the pump of the crud but it never did work again. Expensive mistake) Link to comment Share on other sites More sharing options...
Nick Jones Posted March 19, 2020 Share Posted March 19, 2020 5 hours ago, zetecspit said: I ask as silicone doesn't like petrol True this...... though it will probably survive reasonably well if it rarely sees actual fluid. I'd use a short length of decent quality fuel hose (Cohline 2240 is my current fave) with a blanking rod (5/16" bolt shank?) in it. Link to comment Share on other sites More sharing options...
yorkshire_spam Posted March 20, 2020 Share Posted March 20, 2020 (edited) On 3/19/2020 at 7:10 AM, zetecspit said: How's it lasting Sam? I ask as silicone doesn't like petrol and is fluro-lined (or should be) when exposed to petrol vapour. Certainly applies when using to connect throttle bodies to manifolds etc. Seems to have survived the last 6 years ok: Edited March 20, 2020 by yorkshire_spam Link to comment Share on other sites More sharing options...
Radioactive Man Posted August 9, 2023 Share Posted August 9, 2023 Hi, think i have this issue as the car boot is pretty stinky at the moment. Is it 8mm hose thats needed? I assume so? Thanks Ian Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted August 9, 2023 Share Posted August 9, 2023 26 minutes ago, Radioactive Man said: Is it 8mm hose thats needed? I assume so? 6mm for the vent from memory. Trust I will be corrected if wrong. Link to comment Share on other sites More sharing options...
Radioactive Man Posted August 10, 2023 Share Posted August 10, 2023 Just prized the crumbling mess off. Pipe measures 8mm so 5/16 in old money. The old one just looks like a plastic cap. Not really what I was expecting. Link to comment Share on other sites More sharing options...
Radioactive Man Posted August 10, 2023 Share Posted August 10, 2023 Reckon a 8mm stop end plumbing fitting will do the job. Link to comment Share on other sites More sharing options...
rogerguzzi Posted August 10, 2023 Share Posted August 10, 2023 Hello All I ran pipe down and out the rear of the boot floor then changed the rubber seal to non vented type Roger 1 Link to comment Share on other sites More sharing options...
rogerguzzi Posted August 10, 2023 Share Posted August 10, 2023 Hello All It was probably because USA ones had to vent through what ever it was ? but UK just blanked it off and vented the cap and let the fumes out! Roger 1 Link to comment Share on other sites More sharing options...
