Hamish Posted April 26, 2021 Posted April 26, 2021 Had a day off today so fitted my rose-joint drop links and made new brackets out of robust angle iron. Top hat spacers used as well. car back on the ground and they pivot nicely so not tight with the car weight.
Nick Jones Posted April 26, 2021 Posted April 26, 2021 That looks like it will work nicely Will be interesting to see if you can feel a difference on the road/track?
Hamish Posted April 26, 2021 Author Posted April 26, 2021 I had to make it more robust. I had just flat plate metal to rubber bushed drop links and the plate was bending. not convinced the bolts won’t though.
JohnD Posted April 26, 2021 Posted April 26, 2021 (edited) A longer bolt into the end of the ARB, some spacers, and your lever arm length might be adjustable, a little, making the ARB adjustable for stiffness. This is the ARB and link I've just finished for the Ford Project. The holes in the lever arm have the same function. Edited April 26, 2021 by JohnD
Hamish Posted April 27, 2021 Author Posted April 27, 2021 unfortunately the pic doesn't work for me John H
JohnD Posted April 27, 2021 Posted April 27, 2021 Strange! These days importing pics from my phone is a convulouted process involving Google Photo, obscure settings on the phone, or special software. A real.pain. But I can see it on my phone now, check later if it appears on the PC. What do you see where the pic should be, Hamish? Is there a link to click on?
Hamish Posted April 27, 2021 Author Posted April 27, 2021 hi John its a large square box with a very small blue box in the middle there is a white question mark in the little blue box this is on a MacBook and iphone H
Escadrille Ecosse Posted April 27, 2021 Posted April 27, 2021 19 hours ago, Hamish said: I had to make it more robust. I had just flat plate metal to rubber bushed drop links and the plate was bending. not convinced the bolts won’t though. With regards the bolt bending I assume you mean the one that attaches to the plate. Looks very similar arrangement to the one I have on the Spitfire. I was similarly concerned when I first fitted mine but seem to have held up fine. Early and late suspension incarnations.
JohnD Posted April 27, 2021 Posted April 27, 2021 3 hours ago, Hamish said: hi John its a large square box with a very small blue box in the middle there is a white question mark in the little blue box this is on a MacBook and iphone H It's very clear on my desktop, as well as the phone. Very strange. If I do a "Copy image address" that gets twelve lines (!) of URLcode, gobbledegook, starting "https://lh3.googleusercontent.com" when other pics get one ot two lines. Is this any better? I've copied the image, printed it to Word and copied that Or this, pasted to Paint and copied from there
DeTRacted Posted April 28, 2021 Posted April 28, 2021 12 hours ago, JohnD said: If I do a "Copy image address" that gets twelve lines (!) of URLcode, gobbledegook, starting "https://lh3.googleusercontent.com" John - I think that content is in your personal space on Google. You can see it because you are logged in to the account but no-one else can access it, so a link doesn't work.
JohnD Posted April 28, 2021 Posted April 28, 2021 Does anyone else have a problem with this? Pics from the phone used to be available when the phone was plugged into the desktop, as if it was a secondary hard drive. But now there is nothing to be seen that way, zilch. If you plug the phone in and turn it on in the corret sequence, a window appears with three options, including 'transfer pictures' or similar but it disappears spontaneously after a so few seconds there isn't time to read it! And, somehow, all my pics are being sent to Google Photo, but I can't see the most rcent ones, only those from weeks ago! Sorry to hijack the thread! I started a similar one a short while ago when this all started - I'll go back to that, and copy this there. Meanwhile, back to ARBs! John
