    10.2k
    155.3k
    • Hi folks  my Spanish 45dcoe twin carbs 36mm chokes have never seemed to be reliable settings wise tending to always revert to rich.  the idle mixture screws are also not matching ( number of turns) in any way but set on RR  I do have a set of Italian 40dcoe with 36mm chokes do you think it’s worth swapping them ? will there be a characteristic change? The car is 2288cc should I just swap the various jets to get a base line.    then RR it for next season.  advice thoughts welcome..
    • Hi folks i had a play at the weekend with the 123+ dizzy  I only energised the unit on the car battery it’s not fitted to the engine and I am pleased to say that it appears to work in that the dizzy is talking to iPhone app and visa versa  I used the very basics that my rolling road man gave me after he did the set up post pistons install.  This is what it looks like.
    • Can anyone point me in the right direction please?  I've got a fuel rail with recesses for 14mm injectors.  I also have some pico injectors which fit the whole setup better, but they have 10mm fittings on them.  I've managed to find top hat fittings to take 14mm injectors to 10mm  ones, but not the other way around.  Is there a rubber tube to bridge the gap here or is bonding/interferance fitting in tubes with the correct ID into my fuel rail, is there a fitting I can use? Obviously I could buy different injectors or fuel rail, but I'd rather work with what I've got. Orange injector is the prefered injector, but is a rattling fit into the fuel rail.
    • Hello All              I have used Picasa 3 for years its not updated now but it does for what I want it was a Google program Picasa - Download Just check it's from a trusted source as best you can Roger
    • Erm….. careful with that question.   In this case, free image editing software. Powerful but not especially user friendly (in my limited experience)
    • That is what I do.  Or even photograph the 'printed out  and edited document' then save it as a Jpeg Luddite that I am   Roger
    • Maybe not for Nick's "very large file", but print out the PDF , complete by hand and/or sign it, scan the result.  You can probably save the scan as a PDF.   Send it. John
    • Plenty of free options :  https://www.pcworld.com/article/702374/best-free-pdf-editors.html
