egret Posted October 20 Posted October 20 Can anyone point me in the right direction please? I've got a fuel rail with recesses for 14mm injectors. I also have some pico injectors which fit the whole setup better, but they have 10mm fittings on them. I've managed to find top hat fittings to take 14mm injectors to 10mm ones, but not the other way around. Is there a rubber tube to bridge the gap here or is bonding/interferance fitting in tubes with the correct ID into my fuel rail, is there a fitting I can use? Obviously I could buy different injectors or fuel rail, but I'd rather work with what I've got. Orange injector is the prefered injector, but is a rattling fit into the fuel rail.
Nick Jones Posted October 21 Posted October 21 Like this? https://motorsportsupplies.co.uk/products/adapter-from-14mm-11mm-injector?pr_prod_strat=e5_desc&pr_rec_id=152694fb8&pr_rec_pid=8954839105776&pr_ref_pid=8954838057200&pr_seq=uniform
egret Posted October 21 Author Posted October 21 Exactly what I'm after. My google-fu must be very rusty. Thank you! 1
