JohnD Posted February 14, 2023 Share Posted February 14, 2023 (edited) You may know of my interest in torsion vibration and Triumph's use of crank dampers to suppress it in their long-crank six cylinder engines. I've learnt that Rimmers sell a damper as suitable for both 2L and 2.5L engines! See: Pulley & Damper Assembly - 3/8 inch Groove - 214479 (rimmerbros.com) The original dampers for these two engines were significantly different. The 2.5 crank is much heavier as a result of the longer stroke, and Triumph redesigned the damper to cope with it. The inertia ring clearly needed to be much heavier, so that they incorporated the groove part of the pulley, and fenestrated the hub to make that lighter. 2 Litre damper pulley 2.5 Litre damper pulley Dimensions: Diameter Mass 2L 150mm 1600gms 2.5L 165mm 2600gms Although no weight is quoted, the Rimmers product is clearly the 2.5L type with groove and ring in one piece, but has no fenestrations. I will ask Rimmers if their product has been tested on a 2L crank, and will offer to do so if not. Meanwhile, I suggest that 2L owners should be cautious if they need a new damper! John Edited February 14, 2023 by JohnD Link to comment Share on other sites More sharing options...
yorkshire_spam Posted February 14, 2023 Share Posted February 14, 2023 "Do Rimmers know what they are doing?" Erm, yes and no. I have a history of parts that are not fit for purpose from them with the same cut-n-paste answer of "we'll take it up with the supplier" followed by no meaningful response. Alongside that I've had special tools supplied to me that were in fact just cheap generic tools that were "almost what I ordered" So in terms of that sort of thing, I suspect they know exactly what they are doing - making a profit. I won't order from them anymore unless they are the ONLY place I can get something. Link to comment Share on other sites More sharing options...
Nick Jones Posted February 14, 2023 Share Posted February 14, 2023 23 minutes ago, yorkshire_spam said: Do Rimmers know what they are doing?" I wouldn’t assume so. In this case the fall at the first hurdle is that when you try to fit a 2500 damper on a 2L, it’ll foul on the timing pointer. 2L one’s seem less failure prone. Probably because the rubber is not involved in driving the belts. Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted February 17, 2023 Share Posted February 17, 2023 On 2/14/2023 at 12:48 PM, yorkshire_spam said: I won't order from them anymore unless they are the ONLY place I can get something. Tend towards a simmilar approach although it can be hard. Having said that when I built my 2.5 I basically took the 2L bottom end and swapped out the crank and pistons. Kept the pulley from the 2L. Had to use the 2.5 flywheel because the crank had the 'long' boss but I got that lightend right down until it weighed less than the std. 2L. Seemed happy enough Link to comment Share on other sites More sharing options...
Nick Jones Posted February 17, 2023 Share Posted February 17, 2023 4 hours ago, Escadrille Ecosse said: Kept the pulley from the 2L What did you rev too? Must have been from a pretty early engine if long-tailed, was it cross-drilled too? Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted February 17, 2023 Share Posted February 17, 2023 (edited) 3 hours ago, Nick Jones said: What did you rev too? Road use it was bloody torquey and with the close ratio gearset and J Type TR box there was little need to go much above 5k. For sprints and hillclimbs tried to limit it to 6k as it would be heading off the other side of the TR5 cam but it would run to about 6.5k or so in the heat of the moment before telling you it had had enough by simply refusing to go any faster. Unlike the 2L which just seemed to keep going indefinitely - which was a bit scarey. Everything inside was well balanced though and not sure I would want to do circuit racing with it. 3 hours ago, Nick Jones said: Must have been from a pretty early engine if long-tailed, was it cross-drilled too? I managed to obtain a new old stock crank in the wrapper. I had hoped, but it wasn't cross drilled unfortunately. Engine always had excellent oil pressure. Edited February 17, 2023 by Escadrille Ecosse Link to comment Share on other sites More sharing options...
JohnD Posted February 18, 2023 Author Share Posted February 18, 2023 21 hours ago, Nick Jones said: What did you rev too? Must have been from a pretty early engine if long-tailed, was it cross-drilled too? I found a cross-drilled 2.5 engine for sale locally, and got rather excited, as I didn't know that early ones were built so in the factory. Ho, hum, got it home and discovered that the thrust bearing surfaces in the block were worn away. It's really scrap, but I've still got it! Link to comment Share on other sites More sharing options...
michaeljf Posted April 28, 2023 Share Posted April 28, 2023 Hello John, How worn. You can have them machined and fit a set of Toyota ones as I have mentioned in my thread. Regards, Michael. Link to comment Share on other sites More sharing options...
JohnD Posted April 29, 2023 Author Share Posted April 29, 2023 Please save me a search, Mike? Post a link? John Link to comment Share on other sites More sharing options...
