egret Posted January 14, 2021 Share Posted January 14, 2021 I'm looking to overhaul the front suspension on my mk4 spitfire. As such if anyone on here has any uprated (around 325 lb/inch 9" free length) coil springs then I'd be interested in buying them. Thought I'd ask here before going to the usual suspects who all appear to be out of stock at the moment. Link to comment Share on other sites More sharing options...
Nick Jones Posted January 14, 2021 Share Posted January 14, 2021 Try Faulkner’s if you don’t get any joy on here. https://dfaulknersprings.com/ 9” will need spacers if your dampers have fixed seats. Link to comment Share on other sites More sharing options...
egret Posted January 14, 2021 Author Share Posted January 14, 2021 I'm on what I believe is a totally stock setup and the faulkners spring diameters are smaller that what I've measured. I can't quite get my head around how they will fit the top mounts and shocks. I assume the spacer will be needed to keep the springs located at full droop? Link to comment Share on other sites More sharing options...
Nick Jones Posted January 14, 2021 Share Posted January 14, 2021 Faulkners do 2.25" and 2.5" ID. Spacers (or helper springs) are needed to keep the spring in place at full droop as you say. Link to comment Share on other sites More sharing options...
Radioactive Man Posted January 14, 2021 Share Posted January 14, 2021 Hi I just did similar just before Christmas with springs from Faulkner. 2 1/2" ID, 9" long, 350 lb/inch. Delivery was very fast. I did change the dampers as well with Gaz adjustable ones. Very pleased with the springs, service was brilliant. Link to comment Share on other sites More sharing options...
egret Posted January 14, 2021 Author Share Posted January 14, 2021 Nice, That looks really good. I can't raise the funds for uprated shocks yet, so will have to make some spacers for the stock ones. Cheers all Link to comment Share on other sites More sharing options...
zetecspit Posted January 14, 2021 Share Posted January 14, 2021 My springs go loose, must be 9" springs. I welded a 60mm (approx) pit of pipe that matched the diameter of the top pan. If necessary you can cable-tie the spring to teh damper pan (if it is a fixed pan) Link to comment Share on other sites More sharing options...
egret Posted January 26, 2021 Author Share Posted January 26, 2021 Thanks for the recommendations, Faulkner. 2 1/2" ID, 9" long, 350 lb/inch. Delivery was really fast. Link to comment Share on other sites More sharing options...
