Steve's Vit6 Posted June 6, 2013 Share Posted June 6, 2013 Has anybody got any Vitesse 2ltr front hubs they dont need but are usable. Trying to upgrade my vit6 to later calipers and now find they dont fit and need later hubs also. Trying to get this done for the weekend. I'm in the Portsmouth area. Ta Link to comment Share on other sites More sharing options...
zetecspit Posted June 6, 2013 Share Posted June 6, 2013 Can't help, but interested in the hub issue. I presume you will then need the change wheel bearings and stub axles?? If it helps (probably not) my last spit had GT6 discs fitted to the std spit hubs/uprights, and used princess 4 pot calipers. So the discs should fit ok?. Link to comment Share on other sites More sharing options...
Steve's Vit6 Posted June 6, 2013 Author Share Posted June 6, 2013 I hope I dont have to change stub axles etc. I was hoping this was going to be a cheap and quick upgrade. This is my first Triumph so we learn as we go along. Link to comment Share on other sites More sharing options...
Nick Jones Posted June 6, 2013 Share Posted June 6, 2013 If you change the hubs you will also need to change the stub axles as the bearings are different. Don't know if the bigger stub axle fits your VLs. Not quite sure what you are aiming at - as Clive says you should be able to fit the bigger discs to the existing hubs - the problem comes with fitting the caliper as the brackets are wrong for the 16P calipers and I think the offset is also wrong. However I think you may be able to use Princess calipers - or better, the HiSpec aluminium copies of them which can be used with Capri 2.8 vented discs if you get the wider versions. Nick Link to comment Share on other sites More sharing options...
Steve's Vit6 Posted June 6, 2013 Author Share Posted June 6, 2013 I've fitted the larger discs to the hubs ok and have the correct mounts for16P calipers. I think my problem is going to be that the calipers will come into contact with the hubs. I am awaiting delivery tomorrow of 16P calipers but have had a trial fit using spaced 16P calipers (for 2.8 capri discs) they dont fit and it looks like standard 16P's won't either. Hence my question. Link to comment Share on other sites More sharing options...
zetecspit Posted June 7, 2013 Share Posted June 7, 2013 where are they toughing? any chance you can use washers to move the caliper away from the disc (towards centre of the car) The alternative may be to have the hubs skimmed a little on the face to move the disc the other way I had that done to get capri discs to fit some sense. In fact twice, initially one chap got it a bit wrong Link to comment Share on other sites More sharing options...
Steve's Vit6 Posted June 7, 2013 Author Share Posted June 7, 2013 Should have listened to Nick weeks ago when he first suggested Hispec calipers, but I thought going my route would work out cheaper thinking that stuff was all interchangeable. Shows how much I dont know. Any how WINs has the items in stock new and second hand. Then I'll have some surplus 12P kit that might suit somebody. Link to comment Share on other sites More sharing options...
zetecspit Posted June 7, 2013 Share Posted June 7, 2013 The caliper mounts for the type 12's seem to fetch good money. They are used for people to fit 4 pots to cars, not sure how the market is these days though (used to be £100++) Link to comment Share on other sites More sharing options...
Steve's Vit6 Posted June 7, 2013 Author Share Posted June 7, 2013 So today a refurbed set of 16P's turned up and it looks like a little bit of grinding to the calipers and hub would probably do the trick and make every thing fit. But have decided to upgrade to to 2ltr spec which I think will probably work out for the best as the 2.8 capri discs (future upgrade) didnt seem to fit to well with the 12P setup. Link to comment Share on other sites More sharing options...
Steve's Vit6 Posted June 7, 2013 Author Share Posted June 7, 2013 Also fitting a set of lowered front springs from moss. 9inches compared to the original 12. Hope its not to low?? Link to comment Share on other sites More sharing options...
spitNL Posted June 8, 2013 Share Posted June 8, 2013 You're looking at the uncompressed length. The wire thickness of the lowered spring is much thicker increasing it's poundage, making it harder to compress. You don't give the part numbers so it's impossible to say, but I bet the difference on the car won't be much over 1". Fred Link to comment Share on other sites More sharing options...
Steve's Vit6 Posted June 8, 2013 Author Share Posted June 8, 2013 Hi Fred, you are right the front has been lowered an inch or so. Just about the amount I was looking for. Just need to adjust the bonnet height on the passenger side as its a bit low. Link to comment Share on other sites More sharing options...
