rogerguzzi Posted February 25, 2021 Posted February 25, 2021 2 hours ago, Radioactive Man said: Scary how small old cars are. Had to actually go to the office today so an excuse to get the Spit out. Hello Ian As long as you do not spread to fit the modern!!!!! By the way is that Sherman Tank???? Ha Ha Roger ps the world has gone a bit mad?
rogerguzzi Posted February 25, 2021 Posted February 25, 2021 Hello Ian I forgot to tell you our local TSSC group are going to Spa 6 Hours again all being well! We stay in nice chalets and see some wonderful racing and no posers on track between races which is a BIG plus for me So shall I get our leader to book you in? Last time we did a WW1 memorial site on the way and I plan to do the same this year. Roger ps the Memsahib can come if she is interested ? There were 5 Memsahibs last time!
Radioactive Man Posted February 26, 2021 Author Posted February 26, 2021 The thought of using a passport causes a nosebleed Is this the event in mid May?
rogerguzzi Posted February 26, 2021 Posted February 26, 2021 Hello Ian It is late September/ October. Six Hour Spa - Spa Francorchamps - Motor Racing Legends Travel, tickets and accommodation offers for the Spa Six Hours (traveldestinations.co.uk) Roger
Radioactive Man Posted February 27, 2021 Author Posted February 27, 2021 Finally got round to swapping the wheel studs on the back to the M12 this afternoon... did the fronts with no drama a couple of weeks ago. Rogers patented nut and spacer tube worked a treat. The old rear studs were much esier to knock out than the fronts. Drums back on all good. First wheel on... wont go on... what have I done, is a stud wonky... cant be as the drums are on... bit of head scratching. Check the wheels, holes for the studs are smaller. I had a spare stud, had to double double check. Definitely wont go in. Largest drill bit I have at home is 12mm. Thanks again to Roger for the loan of a couple of drill bits to open the hole out a fraction. 31/64" did the trick Drama over, wheels on car and back in the garage.
rogerguzzi Posted February 27, 2021 Posted February 27, 2021 Hello Ian Glad to be of help We have got to get your car sorted for the Trip to Spa 6 hours later in the year(we do not stop for stragglers!) Joke of course we do but prefer not to ! I am looking forward to Spa 6 hours 3 maybe 4 days of Classic cars racing and not many posers! (what more can you ask for?) Plus last time the cost for the 3 days was £30 and you can go any where ! (makes Classic Le Mans look VERY expensive?) Plus is a better circuit as all the F1 drivers say!(and racing!) Roger 1
Radioactive Man Posted March 21, 2021 Author Posted March 21, 2021 My exhaust is a single pipe sports exhaust, think it was from Pheonix looking at the old receipts. Its the one with a small centre box to quieten things down. The hooligan in me is wondering how much difference it makes and if I should swap it out and just have the back box. Yes I am a child
rogerguzzi Posted March 21, 2021 Posted March 21, 2021 19 minutes ago, Radioactive Man said: My exhaust is a single pipe sports exhaust, think it was from Pheonix looking at the old receipts. Its the one with a small centre box to quieten things down. The hooligan in me is wondering how much difference it makes and if I should swap it out and just have the back box. Yes I am a child Hello Ian You may find it irritating when and if we go to Spa when on the motorways at 70mph Mine has the centre box and I find it just right sporty sounding but not to noisy when cruising at 70mph But each to their own! Roger
rogerguzzi Posted March 21, 2021 Posted March 21, 2021 Hello Ian Just remembered it would probably make your Hi Fi thingy a waste of time! Roger
Radioactive Man Posted April 17, 2021 Author Posted April 17, 2021 (edited) Oil cooler fitted. Have added mounting straps on the top as well. Edited April 17, 2021 by Radioactive Man
rogerguzzi Posted April 17, 2021 Posted April 17, 2021 4 hours ago, Radioactive Man said: Oil cooler fitted. Have added mounting straps on the top as well. Hello Ian I hope it is the Thermostatically controlled type??? and did you ask for the 3/4"UNF filter thread? I can not work out the position is it the same as mine? Roger
Radioactive Man Posted April 17, 2021 Author Posted April 17, 2021 Hi Roger, it’s a thermostatic one, it’s 5/8 though as I didn’t realise that the filters are easier to get in 3/4” thread size. it’s mounted just in front of the radiator. Similar to yours.
Radioactive Man Posted April 17, 2021 Author Posted April 17, 2021 Will be looking for a new full width water radiator. Noticed that where the rad is fixed to the brackets that on one side the rad has some cracks. Seen one second hand on eBay. Better pic of the oil cooler.
rogerguzzi Posted April 17, 2021 Posted April 17, 2021 2 hours ago, Radioactive Man said: Hi Roger, it’s a thermostatic one, it’s 5/8 though as I didn’t realise that the filters are easier to get in 3/4” thread size. it’s mounted just in front of the radiator. Similar to yours. Hello Ian Perhaps you can buy a different threaded bit? (Easy for me as I made mine!) Roger ps yes full width if going to Spain etc UK maybe not plus I like electric fans and as you see I have 2 that come on a different temperatures(2nd one does not tend to come on in UK but has a few times in Spain!)
Escadrille Ecosse Posted April 18, 2021 Posted April 18, 2021 My solution to the problem of fitting the oil cooler. Top mounted below the water rad so there is no mutual interference and bottom mount doubles up as a baffle to to keep the low pressure area behind the air dam separate from the high pressure area at the front of the car and encourage air to flow through both radiators to get to the low pressure area. The holes in the front crossmember are not there for air flow purposes - they're for 'bling' and trying out the hole punch and swaging tool 2
aoie Posted April 18, 2021 Posted April 18, 2021 Thought I should share my Oil Cooler Pics! Buying a modern oil cooler using 10AN fittings was ridiculously cheap on eBay compared to staying with older UHF connections. Hard part was finding oil sandwich plate with 10AN fittings so I re-tapped one. You simply have no room around the spitfire oil filter to work with. Andy
Radioactive Man Posted April 21, 2021 Author Posted April 21, 2021 Mounting on the old rad was cracked on one side and had failed completely on the other... Replaced with full width one.
Radioactive Man Posted May 2, 2021 Author Posted May 2, 2021 A bit to much negative camber me thinks... halfshaft snapped at the hub end. Bit of a 60mph moment! At least the sun is shining.
rogerguzzi Posted May 2, 2021 Posted May 2, 2021 Hello Ian You are not having a lot of luck with that car! Is that the side you replaced the UJ ? I have a complete drive shaft in the shed and I think it is the offside the same if you want a quick fix and it probably has 12mm studs fitted. So if you want it give me a shout. It was on Spitty but I had a couple of new ones fail(yokes came loose) you can read the saga on this site! So I fitted 2 new ones from Fittchets and up to now seem fit for purpose. Roger ps it could have been worse it could have spoiled drive it day for us all Ha Ha
Radioactive Man Posted May 2, 2021 Author Posted May 2, 2021 Hi Roger, it is the offside. I will give you a call when we get home. it was near side we replaced the UJ on. This car is hard work! Driveshaft has sheared. No idea why.
Escadrille Ecosse Posted May 2, 2021 Posted May 2, 2021 That's a bit too much unnecessary excitement. I hope you and the car are otherwise OK. Unfortunately while relatively uncommon it's not unknown for driveshafts to fail.
rogerguzzi Posted May 2, 2021 Posted May 2, 2021 Hello Ian I have just checked and it is the offside one and has 2 studs in it. So would be a quick job(I changed one in an underground car park in Lugo Spain!) Roger
Escadrille Ecosse Posted May 2, 2021 Posted May 2, 2021 Just now, rogerguzzi said: So would be a quick job(I changed one in an underground car park in Lugo Spain!) Now that's what I call being prepared for every eventuality
rogerguzzi Posted May 2, 2021 Posted May 2, 2021 Hello Ian I have found 1 more stud so you only need 1 of yours. I have fitted a slightly thicker circlip to tighten the UJ up a bit more (not that it clicked on Spitty) It is a greaseable one so I have and a couple of pumps into the bearings. I have sorted out a Standard set of bushes in case yours are difficult to remove or knackered. So a couple of hours work and you will be on the road again Roger
