Total Topics151.5k
Loading...ChatboxYou don't have permission to chat.Load More
Great link, thank you Mark. I have an S2000 and the thought of the Honda F20C engine in a Toledo chassis is a bit.......scary! The S2000 weighs around 1200kg compared to the quoted 850kg for the Toledo, so no surprise that it goes a bit. Not overly surprised either that the other Honda engined car has been crashed, though to be fair plenty of S2000s have also been crashed, probably 'chasing Vtec'. I am wary of mine in the wet, even though it is a late version with traction control. Ian
Nephew just sent me the link. https://youtu.be/Dj54KRXCJzM?si=dzc3XWm2HTd8Fm0f
The TRs are probably easier to shroud effectively than the GT6 due to the shape of the bonnet and the way it closes. I have built an aluminium version of the original cardboard radiator shroud and also extended the side cheeks to the limit that the bonnet allows. Used in conjunction with a 12'' Spal fan at fan switch in the top of the rad and a manual override, cooling is pretty much ok in normal UK conditions. Ian
Earlier too, I almost lost my spitfire next to this Rolls! I think at the time there were fewer rolls on the road than there are SUVs now though!
Not just moderns....happened in the 1960 and 70s as well! Ian
Nick When the outside temperature is above 80 Fahrenheit the temperature creeps up to the 200-210 range while driving for extended times slow (or fast). This is after upgrading to the 3-row GT6 radiator and additional oil cooler, was much worse before. Unfortunately fellow Spitfire owners in my local car club have all moved on, so I no-longer have anyone to compare with on long planned drives with the club. In the states we have a water pump re-build Guru called the Flying Dutchman that is still active, he can rebuild the pump and upgrade my impeller to a 5-blade version if I want to pay the price. I just recently watched a Jay leno's Garage you-tube post on his own personal 57 Cadillac were he gave the Flying Dutchman a shout out for the good work he did on that cars water pump. I just revisited my existing water pump installed before the GT6 radiator upgrade and found that it's impeller is smaller than the original pump I still have on the shelf. I don't recall if anything was wrong with the original pump, I believe I just swapped it out as another attempt at the resolving the problem. So looks like I will be re-installing the original to see what happens. I also see a couple more responses to my problem on adding back the radiator shrouds! I do plan to do that in the future but still ruling that out as not the root problem since I did have them originally before upgrading radiators. I did some googling to find images of folks that have added custom shrouds on a GT6, and found a post for a TR6 that closely matches what I would like to-do. Small world appears he is a member of Sideways, so would like to give him a shoutout on all the documentation he did on the build. https://bullfire.net/TR6/TR6-87/TR6-87.html
+1 for using shrouds and cowling. When driving: the forced air flow will take the path of least resistance = around the radiator core, not through it When stationary: the fan will do the work and the air will recirculate. Hot air off the back of the rad will be pulled round the sides and back to the front of the radiator to go round again and get even hotter Both easily validated with a couple of thermocouples positioned on radiator core
Neighbours were away daahn sarf in their Audi A3. Got back very late/very early this morning. The car threw its toys out of the pram on the M6 south of Carlisle. Once recovered off the hard shoulder to a lorry park the AA man diagnosed an injector module fault. Common problem says he, so common that he carried a genuine spare in his van. So £700 lighter (and some eight hours after the breakdown) they were back in Weegie. But says something the man had one in his toolbox. Aren't modern cars splendid -
Indicators that light up but don’t actually flash (although the hazard lights work just fine)…… Ah yes, they all do that sir! Under-spec’d relay sticks closed. It’s built into the hazard flasher switch along with the hazard relay. Someone being too clever again…… New genuine are not cheap. Used ones…. wilI’ll fail in the same way. Apparently there are “field repairs” that can be done……
