foshi Posted March 19, 2021 Share Posted March 19, 2021 trying to fit the bonnet to my vitesse 1600 problem is the carb nearest to the rad is touching have tried all adjustments no joy ideas please paul . Link to comment Share on other sites More sharing options...
Nick Jones Posted March 19, 2021 Share Posted March 19, 2021 Hi Foshi & welcome There isn't much spare room there but they do usually miss. What engine/carbs/manifold combination are you using. Can you lower the engine? Link to comment Share on other sites More sharing options...
JohnD Posted March 19, 2021 Share Posted March 19, 2021 I replied but it hasn't registered, foshi! Are you sure the inlet manifold is original (I think you said, Stromberg's?). But if it's a 1600, then it has all the ports on the same level - it could not have a saloon manifold fitted! What have you done with the adjustment on the hinge pivot? John Link to comment Share on other sites More sharing options...
foshi Posted March 20, 2021 Author Share Posted March 20, 2021 running on original manifold, my car was one of the last 1600 which came with the stromberg conversion , i have adjusted the pivots every way i can think of, the engine cannot go any lower just missing steering rack as it is, at a loss. Link to comment Share on other sites More sharing options...
Nick Jones Posted March 20, 2021 Share Posted March 20, 2021 Then these are the Strombergs 150CDs on the horizontal manifold rather than the angled conversion ones fitted to the Solex manifold. has this bonnet ever been on this car before and what work has been done? can you post some pics? General under bonnet and close-ups of the pivot area..... Link to comment Share on other sites More sharing options...
foshi Posted March 20, 2021 Author Share Posted March 20, 2021 does have the angled set up but my previous 1600 was the same with no problems , will see how i get on today and come back with some pictures . Link to comment Share on other sites More sharing options...
ahebron Posted March 21, 2021 Share Posted March 21, 2021 Is the right hand engine mount sitting correctly? Link to comment Share on other sites More sharing options...
JohnD Posted March 21, 2021 Share Posted March 21, 2021 foshi, I suspect thast this is one of those problems that is most difficult to diagnose from a distance. Your personal details don't include your location - perhaps someone here lives nearby, and could pop around to have a look with you? In a socially distanced way, of course! John Link to comment Share on other sites More sharing options...
Nick Jones Posted March 21, 2021 Share Posted March 21, 2021 Profile says Farnham..... Agree more clues are needed as a minimum. Link to comment Share on other sites More sharing options...
foshi Posted March 21, 2021 Author Share Posted March 21, 2021 had a go today to see if i can sort the bonnet issue , have adjusted the rubber cones , tried lifting the bulkhead slightly , checked the front bonnet mountings are fitted correctly , now have 1.6mm clearance at the lowest point on the carb dashpot not great but not catching the bonnet . a close look at the bonnet the wings look to have been replaced at some point maybe that could be part of the problem? as the car has good shut lines i will leave it , try and find a manifold from a early 2lt or gt6 assuming it will fit the 1600 that way the carbs should sit lower paul. Link to comment Share on other sites More sharing options...
foshi Posted March 22, 2021 Author Share Posted March 22, 2021 update did not have the lifting springs fitted - have just fitted them now have a good 20mm clearance not sure why but happy with the clearance now . Link to comment Share on other sites More sharing options...
