lotus62 Posted January 4, 2018 Share Posted January 4, 2018 Hi all, does anybody know the dimensions from a gt6 upright? measured from the outsite of the brake face. going to make my own vert.links to fit into the 13" steel wheels with disc brake's so need a bit of information just to see if I can be done. (I allready have volvo lobro's, r100 short shafts and mgf uprights) Thanks, Rick Link to comment Share on other sites More sharing options...
oldtuckunder Posted January 4, 2018 Share Posted January 4, 2018 Not everything you need, but might help a bit Link to comment Share on other sites More sharing options...
lotus62 Posted January 4, 2018 Author Share Posted January 4, 2018 thanks, I have this one allready (much worser than this one btw) , missing a few important dimensions unfortunately Rick Link to comment Share on other sites More sharing options...
JohnD Posted January 4, 2018 Share Posted January 4, 2018 Fabricating your own is quite an ambition! MGF uprights come with their own discs. Cutting off the top of the uprright and bolting a piece of Steel tube to take the spring eye did it for me, but it did need fabricated wishbones. JOhn Link to comment Share on other sites More sharing options...
Nick Jones Posted January 4, 2018 Share Posted January 4, 2018 Hub flange outer face to backplate mounting face is 45.65mm. Just lacking the centre line position now. Only assembled units I have at the moments are on cars so not very easy to measure accurately. Nick Link to comment Share on other sites More sharing options...
lotus62 Posted January 4, 2018 Author Share Posted January 4, 2018 thanks Nick, so it is the centerline only for now. any volunteers? lol Link to comment Share on other sites More sharing options...
lotus62 Posted January 4, 2018 Author Share Posted January 4, 2018 John, how often do you need to replace the rose joint? (rod end) i would like to have rubber bushes but the mgf upright is too wide at the bottom. also I like the holes to be in line to make the A-arm easier to fabricate and on the mgf they seem to have a big offset Rick Link to comment Share on other sites More sharing options...
GT6Steve Posted January 5, 2018 Share Posted January 5, 2018 I may have those dimensions documented, I'll look when I get home. If you have Autocad you may be able to take it from a good DWG I have. I'll look Link to comment Share on other sites More sharing options...
lotus62 Posted January 5, 2018 Author Share Posted January 5, 2018 Hi Steve looking forward to them... unfortunately I do not have autocad, but if it is the only way to get them I'll visit a customer with the .dwg file as they have autocad thanks, Rick Link to comment Share on other sites More sharing options...
daisymoose Posted January 5, 2018 Share Posted January 5, 2018 Hi Rick - welcome to the forum After a struggle to kick my laptop into submission (thinks it's still xmas!!!) Dimensions requested are A 106.52 B 122.23 C 110.17 D 86.98 I have a fully drawn up 2D model on CAD if you require any other dims shout Dave Link to comment Share on other sites More sharing options...
lotus62 Posted January 5, 2018 Author Share Posted January 5, 2018 thanks Dave, very much appreciated. Link to comment Share on other sites More sharing options...
JohnD Posted January 10, 2018 Share Posted January 10, 2018 On 04/01/2018 at 10:41 PM, lotus62 said: John, how often do you need to replace the rose joint? (rod end) i would like to have rubber bushes but the mgf upright is too wide at the bottom. also I like the holes to be in line to make the A-arm easier to fabricate and on the mgf they seem to have a big offset Rick Sorry missed tbis q until now. I rebuild every year, using sphericals that cost about £10 each. Not bank breaking. Link to comment Share on other sites More sharing options...
Nick Jones Posted January 11, 2018 Share Posted January 11, 2018 On 05/01/2018 at 9:17 AM, lotus62 said: Hi Steve looking forward to them... unfortunately I do not have autocad, but if it is the only way to get them I'll visit a customer with the .dwg file as they have autocad thanks, Rick Plenty of free downloadable DWG readers out there. You won't be able to change anything but you will be able to see it fine. Some of them even allow you get dimensions. Nick Link to comment Share on other sites More sharing options...
lotus62 Posted January 19, 2018 Author Share Posted January 19, 2018 John, thanks for the answer, bur a rebuild every year is out of the question (I also have an europa and an esprit competing for attention ) Nick, I have seen them before but only after reading your reply I remembered it. I am clearing out the garages at the moment just to get some space to work, my god how much shit you collect over the years. already 3 trips to the waste collectors/recycling points this week. Link to comment Share on other sites More sharing options...
JohnD Posted January 20, 2018 Share Posted January 20, 2018 Replacing roe joints is hardly a rebuild!. Needs the geometry checking, but like replacing track rod ends, if you count the umber of turn it'll be bob-on when you do! John Link to comment Share on other sites More sharing options...
GT6Steve Posted January 20, 2018 Share Posted January 20, 2018 Can you get anything useful from this? It's for the Nissan racing hubs but MAY have a useful dimension? hub.dwg Link to comment Share on other sites More sharing options...
