mattp Posted March 15, 2010 Share Posted March 15, 2010 can spitfire doors as be converted using gt6 glass and quarterlight frames or is it easier to fit complete gt6 doors? thanks Matt Link to comment Share on other sites More sharing options...
GT6Steve Posted March 15, 2010 Share Posted March 15, 2010 I'm not aware of any differences other than between the models. Year to year you should be fine either way... Link to comment Share on other sites More sharing options...
Hurricane1500 Posted March 15, 2010 Share Posted March 15, 2010 Yes they are the same Link to comment Share on other sites More sharing options...
GHR630 Posted March 16, 2010 Share Posted March 16, 2010 Don't Spitfire doors have a brace welded between the inner and the door skin that needs removing in order to fit the quarterlight frame? Link to comment Share on other sites More sharing options...
JMH Posted March 16, 2010 Share Posted March 16, 2010 No, its opposite But some minor differences between years. Early GT6 doors did have a small bracket between skin and frame at the top. Link to comment Share on other sites More sharing options...
mark spit Posted March 16, 2010 Share Posted March 16, 2010 The only other thing to be aware of is that the GT6 glass curves in at the top whereas the Spit glass is flat so once changed you don't get as good a seal against the hood. Mind, my old vinyl hood was absolutely crap so another draft wasn't a problem really. Recently had a mohair hood professionally fitted and that seals up okay. Not that I drive with the hood up very often anyway. Take care with the quaterlights as well, put plenty penetrating solution on the hinges before trying to open them, especially the passenger side as they probably haven't been opened as often as the drivers side. Replacement glass is scarce and the top hinges are unobtanium (I think) if they snap. Well worth doing for the improvement in driver comfort though. Cheers Mark Link to comment Share on other sites More sharing options...
mattp Posted March 16, 2010 Author Share Posted March 16, 2010 the plan is to run the spit with a hardtop which will be bolted to the roll hoop. no plans to remove the hardtop as it'll be a fuel injected 1147cc eco-daily driver hence the desire to get some quarterlights fitted for ventilation.... Link to comment Share on other sites More sharing options...
James Posted March 16, 2010 Share Posted March 16, 2010 Remember you'll need special glass cut if you've got a roundtail Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted March 16, 2010 Share Posted March 16, 2010 Used GT6 Mk2 doors on my Mk3, bolt on job bar one small mod I forgot. Link to comment Share on other sites More sharing options...
mattp Posted March 16, 2010 Author Share Posted March 16, 2010 Remember you'll need special glass cut if you've got a roundtail can you clarify....i've got an omnibob bubble hardtop for square corner doors glass so i thought i was sorted on that. Link to comment Share on other sites More sharing options...
mattp Posted March 16, 2010 Author Share Posted March 16, 2010 since seeing this picture a while back, i've had the hankering to fit a mk4/1500 hardtop to a roundtail. i've got a steel one in stock but am on the hunt for a fibreglass one to keep the weight down. the mk4 hardtop gives the appearance of a lower roofline and coupled with the straight c pillar down to the bulge of the rear wing/arch, it reminds me of \/ just one of those things that floats my boat............. Link to comment Share on other sites More sharing options...
DaveNotSoSideways Posted March 16, 2010 Share Posted March 16, 2010 Different screen, screen frame and I don't believe the early and late tops are interchangeable, without lots of work, like grafting a Mk3 windscreen frame on the Mk4, thats possible, you just swap the entire dash top over, drill some holes. Screen frame part of the body on late cars, its removeable on the early ones. Link to comment Share on other sites More sharing options...
mattp Posted March 17, 2010 Author Share Posted March 17, 2010 hmmm, a bit confused now. my Mk4 steel hardtop and the omnibob bubble mk4 hardtop both fit. had them both bolted to the mk2 screen frame and with some custom bracketry to the b pillars. Current doors and glass are mk2, so what you are saying is the gt6 doors/quarterlights won't fit up against the screen frame and the hardtops i have shouldn't fit the mk2? Link to comment Share on other sites More sharing options...
