sparky_spit Posted August 24, 2022 Share Posted August 24, 2022 I have been gifted a vacuum gauge. I'm in two minds whether to fit it or not. Is it going to tell me anything I don't know already? If I do decide to fit it permanently can I tee its feed pipe into the vacuum pipe I already have that goes from the inlet manifold to the Aldon Amethyst ignition box, without upsetting the Amethyst? Link to comment Share on other sites More sharing options...
PeteStupps Posted August 25, 2022 Share Posted August 25, 2022 I don't know the answers but am interested, because my brown Spit6 has a vacuum gauge and I'm not entirely sure what the point is. Link to comment Share on other sites More sharing options...
Nick B. Posted August 25, 2022 Share Posted August 25, 2022 Is it not mostly a meter measuring how far you pres the accelerator pedal down? I have also seen them marketed as econometers. Helps you drive less fun. I would not bother (then on the other hand I have bothered about volts, oiltemp and aoipressure) I would fit it if I found pleasure in seing gauges operate :-) Cheers Nick Link to comment Share on other sites More sharing options...
PeteStupps Posted August 25, 2022 Share Posted August 25, 2022 3 hours ago, Nick B. said: I would fit it if I found pleasure in seing gauges operate :-) That is an important consideration, to be fair Link to comment Share on other sites More sharing options...
Nick Jones Posted August 25, 2022 Share Posted August 25, 2022 Has some value as a diagnostic tool, otherwise mainly econo-meter as stated. I wouldn’t chop a hole in my dash for one. 1 Link to comment Share on other sites More sharing options...
sparky_spit Posted August 25, 2022 Author Share Posted August 25, 2022 Okay thanks. I think I'll file it on the shelf with all the other treasures to be ebayed when I get round to it. Link to comment Share on other sites More sharing options...
RichardB Posted October 9, 2022 Share Posted October 9, 2022 Had one for a while, Nicks thoughts summed up my experience. Took it out when I put megasquirt in as the logs included vacuum readings, for economy once you've used it for a bit it's not hard to remember what sort of driving will generate the most vacuum. Just to add it's particularly useful for TR6 owners. Vacuum has particular importance on the Lucas PI system, if a worn engine starts to read less vacuum then the metering unit will throw more fuel in (which probably starts a vicious cycle of creating more bore wash and thus wear). Link to comment Share on other sites More sharing options...
