aoie Posted February 9, 2018 Share Posted February 9, 2018 On 1/1/2018 at 9:38 AM, rogerguzzi said: Hello All Happy New Year and may all your troubles be Triumph,d I have been having anther look at my valve guide seals and I find if I leave the guides at 0.750" above the head there is not enough space under the collar to get the 0.405" lift that the new camshaft will give and the valve at fully open is just 0.015" below the face of the head. I have found by machining a chamfer on the guide the seal sits slightly lower on the guide and if I fit the guide to 0.700" I can just get the 0.405" with a few thou to spare(just) So I thought I could I could just bullet nose the guide a bit more as I do not want to shorten the guide! What do we all think? Roger ps I also noticed the 1300 cc head has slightly smaller inlet port castings! but I think I can open them up to 1 1/4" dia Roger You lost me on which valve seal you settled on! Is the Topran 100207 what you are referring to as the VW seals? Andy Link to comment Share on other sites More sharing options...
oldtuckunder Posted February 9, 2018 Share Posted February 9, 2018 If you want a free set of the VW ones (green tip) PM me an address and they are yours. Alan Link to comment Share on other sites More sharing options...
aoie Posted February 9, 2018 Share Posted February 9, 2018 Alan Yes I would be happy to take some VW seal off your hands I tried to send you a PM (twice) and received error that oldtuckunder cannot receive messages! Sent A message to myself just to make sure i was not doing something wrong. Try sending me a PM wand I will reply to it! Also please send me the part number you used when you purchased them, i just picked up a 2nd matching cylinder head to the one I'm currently rebuilding so i'm probably going to need more. Andy Link to comment Share on other sites More sharing options...
oldtuckunder Posted February 9, 2018 Share Posted February 9, 2018 You have PM, well actually two, problem was my inbox was full, looks like though the website is new, the limits are a bit Dickensian I have deleted some prose and all seems to be well now for a bit. Alan Link to comment Share on other sites More sharing options...
