10.2k
Total Topics152.1k
I really don't suspect it's anything major like cam timing? I went through that saga a few months ago as you all can see on here. Like an exam, showed my working too! So it can't be anything like that... surely. I'll be back home from the gfs later to start the investigation. Only trouble is I have no beer
I was hoping the solution would come to me in the same way but no luck yetš
I had checked thisanticlockwise, i doubted myself and clecked multiple times
I mean it was a right bastard to get it started anytime, I mean really rough, missfire and backfire. I can't get it running long enough to get out with a timing light Vacuum leaks, yes that could be possible. I think I'll go around and check manifold and carb nuts and bolts etc.
Blimey, that is some serious improvement from the Senior Management there. You need to be watching your back too!Ā -
Hah! you are like @GT6MK3ā¦. ā¦.. you just like to go fastĀ Ā āI feel the needā¦. For speed!ā -
I know itās a different car but one of my mods before going to a more powerful piston rearranging engine was to fit (sorry - have fitted) my 4:1 with lsd. The 4:1 made such a difference to the fun value. And turned me back into a teenager ( and those who know me thatās quite a Time Machine !!!) with the fun of the acceleration.Ā
What a ā¦ā¦ā¦ I shouldnāt write what I really think. i have being in that situation and have been helped and hindered Ā and I have help out others. i must say when the horns are put into use I stop pushing lean on the car and āsmile and waveā Ā gesturing for them to help push ??! Help or go nowhere. however you had a reasonably successful run out and got home under your own steam Ā thatās a result in my book Ā Ā Ā
This is the crumpled timesheet that I thought I had posted earlier..........
