Fredell1977 Posted May 19, 2017 Share Posted May 19, 2017 Dear all. I need some help. I found a gearbox for a mk4 spit but it seems it was originally on a US car. Are there any issues with getting this installed on a UK car? Are the ratios different? Thanks Link to comment Share on other sites More sharing options...
GT6Steve Posted May 19, 2017 Share Posted May 19, 2017 I'm pretty sure it will be fine going into a UK car whereas if going into an Aussie car it would rotate backwards... Link to comment Share on other sites More sharing options...
Nick Jones Posted May 19, 2017 Share Posted May 19, 2017 I'm pretty sure it will be fine going into a UK car whereas if going into an Aussie car it would rotate backwards... D'ya think? OP: No ratio differences for gearbox. Some models have different rear axle ratios Euro/US. Provided your car has a 3 rail box (reverse down and to top left) and the replacement box is the same then you should be ok. Only other obvious thing to look out for is that they both have round output shaft flanges (square flanges from Mk3 Spit and earlier or Herald and indicates 3 synchro 'box) Nick Link to comment Share on other sites More sharing options...
