Darren Groves Posted April 30, 2017 Share Posted April 30, 2017 Any recommendations on whether the Over Run Fuel Cut should be turned on my Microsquirt? If so, would the default settings be OK? Darren Link to comment Share on other sites More sharing options...
Nick Jones Posted April 30, 2017 Share Posted April 30, 2017 Yes, can work ok. Those settings look reasonable - KPa might need tweeaking - depends what your engine actually does and suggest that the coolant temp should be 70ºC. You only really want it to do it when fully warmed up and you are right off the throttle or it makes for a jerky drive. Nick Link to comment Share on other sites More sharing options...
RichardB Posted May 1, 2017 Share Posted May 1, 2017 The default settings are quite conservative, agree with Nick that it looks fine. I had it down to 0.7s delay, 1150rpm, 30kPa, 45c and 4% TPS, though that was after months of refining the VE table. It's a must have with the megasquirt, the fuel savings you'll make versus not having it (or running carbs) are substantial! Link to comment Share on other sites More sharing options...
Darren Groves Posted May 1, 2017 Author Share Posted May 1, 2017 Thanks Nick/Richard, Had a bit of time to play with this today, I set the RPM to 1250, Delay to 0.7s, Temp to 70°C, 30kPa as I seemed to be around mid 20's on the overrun and the TPS at 4% as mine is at 3% at idle. This had no adverse affect to the smoothness of the drive and I could see the AFR reading go off the scale lean on the overrun, so I'll just leave that as it is as it seems to work fine. One odd thing though is that my Smiths rev counter drops to 0 as soon as the fuel cut kicks in and comes straight back as so as I touch the accelerator and the fuel cut stops, the revs on the Tunerstudio dash are still, any ideas? Darren Link to comment Share on other sites More sharing options...
Nick Jones Posted May 1, 2017 Share Posted May 1, 2017 One odd thing though is that my Smiths rev counter drops to 0 as soon as the fuel cut kicks in and comes straight back as so as I touch the accelerator and the fuel cut stops, the revs on the Tunerstudio dash are still, any ideas? Darren That's odd. Mine definitely didn't do that on either the MS1 extra firmware (Vitesse, some time ago) or on MS2 extra firmware that I had on the PI. Vitesse currently doesn't have it as using MS2 with original B & G firmware which doesn't have the facility. I could upgrade I suppose but the B & G is seamless whereas the Extra version on the PI would do strange things sometimes. Where are you taking the tacho signal from? Nick Link to comment Share on other sites More sharing options...
Darren Groves Posted May 1, 2017 Author Share Posted May 1, 2017 I'm using the Tacho Out (Pin 35) on the Microsquirt, the Rev Counter was converted by Speedycables and I then just had to use a pull--up resistor but it's worked absolutely fine since then. Darren Link to comment Share on other sites More sharing options...
Nick Jones Posted May 1, 2017 Share Posted May 1, 2017 The Microsquirt must be turning it off then - possibly turning the whole spark off? My Vitesse tacho is driven by the diagnostic output on the EDIS plus a little amplifier circuit that mimics the coi,l so wouldn't have been affected as EDIS would run all the time whatever the ECU did. Likewise, my PI tacho (current sensed) was triggered by the coil supply and also had EDIS. Seems like a very odd thing to do though..... Nick Link to comment Share on other sites More sharing options...
Darren Groves Posted May 2, 2017 Author Share Posted May 2, 2017 I did try to pick up the tacho signal from the coil originally but it didn't work, though that was before I'd had it converted so that might be an option if I can't resolve through Tunerstudio. On the plus side it's a visible reminder that I'm saving fuel . I posted the question on the MSExtra forum, but need to supply a data log, job for the morning. Darren Link to comment Share on other sites More sharing options...
Triumph-V8 Posted May 4, 2017 Share Posted May 4, 2017 As the points pickup in the distributor is no longer needed why not remove the condenser, fit a pullup resistor and take this for the tacho? By the way: I would set the TPS to 0 and 100% with Tunerstudio because whenever something is changed with the throttle the electronics can be quickly adapted. Link to comment Share on other sites More sharing options...
Darren Groves Posted May 15, 2017 Author Share Posted May 15, 2017 As the points pickup in the distributor is no longer needed why not remove the condenser, fit a pullup resistor and take this for the tacho? Dizzy long gone, I have the Ford Coil Pack mounted there now. By the way: I would set the TPS to 0 and 100% with Tunerstudio because whenever something is changed with the throttle the electronics can be quickly adapted. Are you saying that the TPS should be calibrated to 0% at it's partially open idle position? I calibrated the 0% without the throttle cable connected so it was fully closed, then opened up slightly to get the desired idle speed, so it's currently at 3% at idle. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ I am running an older version of the MSExtra Firmware, so may just update it to the latest version in case the rev counter thing is just a bug, as it seems nobody else has this problem, the MSExtra Forum has provided no clues either. Just so I don't screw up my current tune during the process, obviously I save it and reload the after the update, but are there any settings that will need manually changed after. I seem to recall reading that some sensors need re-calibrating after a firmware upgrade, but can't find where I read that. Darren Link to comment Share on other sites More sharing options...
