Sprint95m Posted October 5, 2020 Share Posted October 5, 2020 My sister has a Vauxhall Zafira with a very dulled headlamp lens on one side only. Can anyone recommend a good kit for restoring clarity please? Thanks, Ian. Link to post Share on other sites
Gt64fun Posted October 6, 2020 Share Posted October 6, 2020 Ian I have recently used a 3M Headlight Restoration System kit on my 2006 Mazda 6MPS. The kit comes with 500g/800g/3000g sanding discs, a sponge pad and polishing compound, a hook pad for mounting in a drill and even some nice heavy masking tape. Takes a bit of time but worked well. You will probably find yourself doing both lenses, but may not have to start with the 500g if the better one is not so aged. Ian Link to post Share on other sites
zetecspit Posted October 6, 2020 Share Posted October 6, 2020 I bought a cheap polishing mop off ebay for a few quid, fits in a drill. Then used polishing compound, bit coarser than T cut, to polish teh lenses. Works well enough, maybe finish with a finer polish after. Works well enough, but indeed, if the lenses are really bad some very fine wet/dry paper would speed things up. Link to post Share on other sites
Sprint95m Posted January 28 Author Share Posted January 28 Sorry I should have replied sooner, much sooner. Thanks for the advice. I have a confession to make, I haven't done anything about this. The car needed a small bit of work for the MOT and I didn't get around to doing anything about the headlamp lenses. Ian. Link to post Share on other sites
