mattius Posted April 19, 2017 Share Posted April 19, 2017 Anyone got any recommendations for an alternative to Por15? I normally use Chassis coat black, but the prices recently have sky rocketed... Link to comment Share on other sites More sharing options...
oldtuckunder Posted April 19, 2017 Share Posted April 19, 2017 Vatcan then Hammerite Alan Link to comment Share on other sites More sharing options...
Nick Jones Posted April 20, 2017 Share Posted April 20, 2017 ?? Ah, Vactan http://performance-chemicals.net/vactan/ Should be good over a rusty/rust pitted surface. Not sure about the Hammerite bit, I've found it prone to chipping. We tended to use a high zinc brushable primer following by a brushable synthetic paint which can be colour matched if you wish. Nick Link to comment Share on other sites More sharing options...
oldtuckunder Posted April 20, 2017 Share Posted April 20, 2017 Sorry Dyslexia serul Brilliant stuff apply to wet or dry metal/rust, over paintable as soon as dry, maybe less than 10 mins on warm day, to be honest you don't even need to overpaint if its a low abrasion area, only to make it look pretty! I was introduced to it by a local plant engineer about 10 years ago, since which I have used it on cars tractors and just about everything. Know what you mean about Hammerite, but I have found that a thin spray coat on top of Vactan and it lasts without chipping, I think the Vinyl layer provides a slight flex base that stops the chipping you get with hammerite on bare metal. I also find that a couple of thin spray layers of hammerite is way better than a thicker brushed layer. Alan Link to comment Share on other sites More sharing options...
egret Posted April 20, 2017 Share Posted April 20, 2017 I've got a pot of kurust and hammerite smooth black metal paint sat in the garage. I bought it in a fit of enthusiasm hoping to get the suspension components painted prior to baby number 2 arriving. Sadly nothing has happened since then so I can't comment on the quality of it. I was hoping that good surface prep and a gentle life would mean this approach is adequate for 5-10years. Link to comment Share on other sites More sharing options...
Sprint95m Posted April 21, 2017 Share Posted April 21, 2017 I use the paint sold by agricultural machinery suppliers. It seems to last pretty well, indeed it did better than some powder coated suspension items I had. I am thinking that the secret here is to ensure you use a good zinc primer? Ian. Link to comment Share on other sites More sharing options...
