Urge Posted June 5, 2014 Share Posted June 5, 2014 Hi I want to fit a set of retractable seat belt in my spit mk2 one of the fixing points is going to be the main loop tube of my roll cage, a little higher than shoulder lever. these will be my daily driving belts, I have just fitted a harness bar to my roll cage, and on the odd track day, the harnesses will come out to play. so, what does one look for in a retractable seat belt???? The universal type ones look all prity much the same, bit on the cheap side and only one years warrenty Link to comment Share on other sites More sharing options...
motov8id Posted June 5, 2014 Share Posted June 5, 2014 I have used rear seat belts from 80's Volvo sedans they mount horizontally and are easilly obtainable Link to comment Share on other sites More sharing options...
Urge Posted June 6, 2014 Author Share Posted June 6, 2014 Thanks for the info I wish the belts to be vertically mounted. so as the reel is at the base of the roll cage main loop. then the belt will run up the loop to sholder hight to the eye fixing point. then when needed. ill pull them down over me. What I am looking for is quality. Hopefully even with hard alloy buckels etc. thinking about the rain and rust. Secondly. I would want a E mark on them. Link to comment Share on other sites More sharing options...
