microx Posted August 19, 2016 Share Posted August 19, 2016 My 2L pinto currently has a Kent FR32 fast road cam, I use the car only for road use. I also have a burton high torque which has a much wider rev band and consequently more low end tractability. I have not yet tried the hi torque and don't want to do all the work only to find I am disappointed with the performance. Does anyone have experience with these cams in a pinto. Link to comment Share on other sites More sharing options...
esxefi Posted August 20, 2016 Share Posted August 20, 2016 probably not here, most posting is about triumph engines, but the pinto is ohc so it is fairly easy to change(compared to a triumph engine anyway) it over to try.as they say 'if you don't try you will never know'. might be worth trying the retro rides forum as it covers all makes. Link to comment Share on other sites More sharing options...
