thebrookster Posted August 5, 2024 Posted August 5, 2024 I'm certainly interested to see how you fare with these. One of my big bugbears with modern lights is the lack of care taken over beam spread, so I'm rather chuffed you have taken the time to check this! Kudos to you!
PaulAA Posted August 5, 2024 Posted August 5, 2024 Mike Interesting - I tried swapping to Philips H4 LED lamps in standard Lucas curved and prismed 7" lens on the TR6 a couple of years ago, and was roundly disappointed. The vertical and horizontal beam spread in both main and dipped was random to the point that it was not possible to distinguish between the two, except that main created slightly more glare for oncoming drivers. I refitted the lamps several times, without improvement. Obviously, the LED lamp position works less efficiently with the standard reflector and prisming, and blind spots are created by the diode holder. The better solution would be to use a sealed beam LED unit, but I've swapped back to halogen and am much happier. Also, the 'cold white' of LED (I think they're 6500 Kelvin or more) gives it a restomod appearance and, for me, the warm white of halogen works better aesthetically. Paul
Gt64fun Posted August 5, 2024 Posted August 5, 2024 I have Cibie H180s with Philips Visionplus H4 halogen bulbs, which are switched via a pair of relays. Beam pattern and intensity on dipped and on main beam are awesome! The Cibies are expensive but worth it in my opinion. Ian
mpbarrett Posted August 6, 2024 Author Posted August 6, 2024 Drove the car at in the dark last night. The new LED bulbs are very good and very bright. Beam pattern good but the difference between full and dipped is very marked, with the dipped too low. I had noticed this when I had halogens (Osram night breaker) in them but it seems much more marked with the LED bulbs. I guess the light source, LED chip, is in a slightly difference position and size. Will have a look at what type of lens I have in the car! Cibie are a bit expensive!
RogerH Posted August 6, 2024 Posted August 6, 2024 1 hour ago, mpbarrett said: Drove the car at in the dark last night. The new LED bulbs are very good and very bright. Beam pattern good but the difference between full and dipped is very marked, with the dipped too low. I had noticed this when I had halogens (Osram night breaker) in them but it seems much more marked with the LED bulbs. I guess the light source, LED chip, is in a slightly difference position and size. Will have a look at what type of lens I have in the car! Cibie are a bit expensive! Set the dip to the correct beam pattern cut-off and let the main beam do its own thing. The main beam will not be on to bother on-coming traffic - will they !! Â Roger
Nick Jones Posted August 6, 2024 Posted August 6, 2024 2 hours ago, mpbarrett said: Beam pattern good but the difference between full and dipped is very marked, with the dipped too low. So adjust the lights up a little…. Doesn’t take much. Couple sacks of sand in the boot will likely work too 1
mpbarrett Posted September 8, 2024 Author Posted September 8, 2024 going back to the Headlights fitted new lens and the difference between full and dip was much better. Fitted LEDs to the sidelights and indicators. Needed to clean and paint the reflectors behind the lens and now much better and brighter. Â Â
mpbarrett Posted September 8, 2024 Author Posted September 8, 2024 (edited) Just back from the 10CR. A very long route this time with most days being 8 or 9 hours driving. Myself and Jane (who navigated but didnt drive) we cut lots out of the route but still did more motorway driving than we wanted to do. The problem is that this years 10CR went to south of France; its a long way so you need to do a lot of driving... The car had lots of small issues, none were show stoppers; The night before I noticed one of the 'Welch' plugs on the 3 rail gearbox had gone missing and explained why we had some much oil around the gearbox, only noticed when I was looking from the engine compartment. Temporary fix was an ali plate and lots of sealant. Speedo broke before we got to Dover, Horn stopped working, Electric fan connection fell off, Small petrol leak from a hose under the car (that I had missed when I worked on the car before we went on the trip). Solved by a new clamp on the hose but noted the pipe is looking rusty. At least it the return flow so not under any pressure. Biggest problem was a new issue, jumping out of 3rd gear when on over run, This was a real problem going down some of the passes. Need to think about whats causing this to happen.... Good bit, the baro correction worked well (leaning the mixture as the barometric pressure dropped), tweaked after the first pass (2000m) and we had full power up the next pass (2600M). But the idle was all over the place going from rich to lean. I adjusted the tickover to make it higher but off the mountains this meant it was running lean and started to get hot, probably need to tweak the map on higher revs at tickover to solve this. The most worrying were noises from the O/S rear drive bearing this got worse and started to make a grinding sound on left hand corners. I had checked the bearing before hand but could not find and play in it so this will need looking at. But we have done over 2000 miles on a lot of nice driving roads, a few very high passes and lots of motorways. The car seems happy at 75 but will easily go to 85 so it will keep up with most of the traffic. Weather was 'interesting' with some amazing thunderstorms and torrential rain on the Italian motorways.... We stayed in some nice places and had some good food and banter so a good trip! Mike  With hard top on which worked well. Not yet wrapped or resprayed! typical morning car fettling Edited September 8, 2024 by mpbarrett 2
PeteStupps Posted September 8, 2024 Posted September 8, 2024 Well done Mike, good to read you got around despite the niggles and issues. Nothing useful to suggest on the gearbox but will be interested to hear other's opinions on a likely cause. Something to do with the synchro hub maybe?Â
Hamish Posted September 9, 2024 Posted September 9, 2024 Always impressed with you guys that do these long trips in your cars. I’m concerned with the speed events I do ! And they add up to 7 miles at a good event with a few runs. (SHELSLEY is more like 4 !) With probably an accumulated 1hour + idling. Much respect 1
Escadrille Ecosse Posted September 9, 2024 Posted September 9, 2024 (edited) Good run. Might be the welch plug and 3rd gear are related. Check detents on the selectors and as Pete says travel on the synchro hub for detents there too. And dreaded split mainshaft spacers. Â Edited September 9, 2024 by Escadrille Ecosse
Nick Jones Posted September 9, 2024 Posted September 9, 2024 On 9/8/2024 at 9:38 PM, mpbarrett said: jumping out of 3rd gear when on over run That bloody circlip on the end of the mainshaft? On 9/8/2024 at 9:38 PM, mpbarrett said: But the idle was all over the place going from rich to lean. Partly because it goes to a completely different part of the map at idle due to the pressure change I think….. i was and still am planning to do some altitude tweakery but a bit nonplussed today as going over the Grand St Bernard today without altitude correction caused no problems. It even idled at the top (albeit very slowly) which it’s not done before. I can only assume that 8% authority on the EGO correct (is enough for it to self correct.Â
Nick Jones Posted September 9, 2024 Posted September 9, 2024 Sounds like you had a good run though. Assume you were mostly off the peage? It’s fearsome expensive these days. Getting back from Grenoble in reasonable time without spending a fortune is going to be a challenge!
mpbarrett Posted September 10, 2024 Author Posted September 10, 2024 14 hours ago, Nick Jones said: That bloody circlip on the end of the mainshaft? Partly because it goes to a completely different part of the map at idle due to the pressure change I think….. i was and still am planning to do some altitude tweakery but a bit nonplussed today as going over the Grand St Bernard today without altitude correction caused no problems. It even idled at the top (albeit very slowly) which it’s not done before. I can only assume that 8% authority on the EGO correct (is enough for it to self correct. I think you are correct but I wish I had got Jane to monitor it and then I could have seen where it was going on the map, even better would have to log the data but forgot!
mpbarrett Posted September 10, 2024 Author Posted September 10, 2024 14 hours ago, Nick Jones said: Sounds like you had a good run though. Assume you were mostly off the peage? It’s fearsome expensive these days. Getting back from Grenoble in reasonable time without spending a fortune is going to be a challenge! A lot of Peage so yes expensive. The 10CR is an expensive trip these days... I wished we had got a Tag as some of the machine were unreachable from the Herald if you have short arms!
Nick Jones Posted September 10, 2024 Posted September 10, 2024 Actually going to try and use Ellis’s route from 2013 for our run north at the end (but in reverse and avoiding Reims). We’ll see - peage will always be minutes away if it’s taking unbearably long. Big day planned for tomorrow from Courmeyeur to La Mure involving several high passes…. The laptop is charged… 1
mpbarrett Posted February 10 Author Posted February 10 I have been doing a few jobs on the Herald. Door hinge had seized that made closing the drivers door interesting...took it apart and knocked pin out, it was on a spline and not welded in, and cleaned and lubricated. Now I can close the door! Speedo stopped working on the way to dover for the 10CR, cable had moved close to the exhaust and got hot and dried out. Replaced it, and fixed it so it cant get close to the exhaust, and put in a new RT drive, but it only lasted about 100 miles before stopped working. This time the RT drive was broken, with teeth damaged. The cause was the Speedo bearing drying out. Cleaned and lubricated the speedo, new RT drive and all seems to be working. And the Speedo now matched the GPS speedo, previously it was reading lower that the GPS speedo. Took the car for its annual MOT today, not needed but I am happy for someone, my friendly garage that I have used for 30 years, else to look over the car and test itsbrakes. It passed with a couple of advisories, usual wheel bearing play, oil leak from gearbox which I know about and rear tyres down to the markers, again I was aware they had worn. So no nasty surprises. The tyres are Uniroyal rain experts and I put them on in 2022, so 3 years but 2 10CR's (fully loaded car with too many spares in the boot) and a thrash around wales early last year. So maybe in total 6000 miles. The wear in the rears was very even so dont think the alignment is out. Front are fine. I will put some new ones on the car as we are off to Scotland in May, and I really like the grip from the tyres in the wet.... Mike Hinge with pin driven out and being cleaned. I drilled a hole in the housing so I can now get oil into the shaft. New RT drive from Moss but with circlips so you can take it apart, which is nice.  broken RT drive, shaft is crimped into body so has been broken. Damage on gears as well, not very well made .  My collection of RT drives including one with home made drive spindle, which will slip if the cable or speedo starts to fail which protects the RT drive. 1
