Greetings Gurus,
I have a set of Canley CV axles that I am fitting to GT6 Rotoflex hubs/vertical links. My problem is, when I obtained the GT6 rear suspension components they did not include the spacer and shim used to position hub at the correct depth on the axles. I contacted Canley who replied "Build shafts as original. using original spacers/shims".
I have checked all the normal suppliers and cannot find the spacer. I do find shims in both .003 in and .005 in thickness. The Canley website seems to suggest that the standard spacer is .139 in.(just a number in a description) and, on the pictorial parts diagram, what appears to be a hand written note,  the shim seems to be listed as .003 in.
Question: Can anybody verify the thickness of the thick spacer and the thinner shim?
Thanks again!
If building up from scratch it will all need setting up and you cannot rely on anything "standard"
I have never done it, but it is a faff from what I have been told. I think the proceedure is on the canley site somewhere.
It sounds like you have a box of rotoflex bits, but not assembled?
The numbers you quote sound about right.  I’ve not done one of these for many years, but they are fiddly.
The spacers were unavailable for a time - are they available now?
May possibly have some but I’m a long way from them just now…..
@Zetecspit
I will have another look around the Canley site to see if there are any guides/instructions.
@Nick Jones
Spacers are "NO LONGER AVAILABLE" at Canley. I checked all the normal sites and it seem nobody has the spacers. I will do a bit more searching. Might need to just make a set.
If you have a lathe then make the spacers a little long, do an initial build, measure endfloat resulting and then dismantle to reduce the spacers by the amount necessary to give the specified end float. Possibly I still have spacers in my parts pile but will be a little while before I can check.
5 hours ago, jeffc said:
@Zetecspit
Apologies, I thought it was there.
I have my venerable kipping catalogue here, that has the fitting procedure
7 hours ago, Nick Jones said:
Pretty sure that’s still in the technical archives?
Edit: Not there now that I can find.
So it wasn't just me then.
I quite like my old Kipping catalogue.
@Nick Jones A lathe would be useful for many projects. Can you also provide recommendations for how to convince my wife to park her car outside?
@zetecspit Your procedure picture will help. Thanks for sharing.
@iani Thanks for the link. But.... then I wont need a lathe ..... and I will have even fewer reasons for asking my wife to park outside. Pros/Cons.
I do not know where Nick Jones is but I am in the States and the listing suggests 28.78 GBP. If I need two sets, will I need to pay two postage fees?
I’m in the UK, but postage for me is showing as £22.91.  No idea why I see this and Phil sees £ 2.00.  Possibly eBay thinks I’m in Australia as I and this phone were until a couple of days ago.  I would think that one postage fee would cover two sets but you should check with the vendor. He is a reasonable man in my experience.
As for convincing your wife her car should live outside…… good luck with that!
Your problem is precedent; my wife has known from the outset that garages are for “toys” and tools and daily drivers live outside…. The flip side is that she also knows that her personal mechanic will keep her car running and works for food and favours…. So there is a price to be paid!
I suspect that is the eBay global shipping programme cost. I doubt you would need to pay two sets of fees but still seems a bit dear. I would suggest messaging Mark. He's a decent guy and might be able to do you a better postage deal.
  • 3 weeks later...
Good to know a second source exists. The ebay source appears to be increasing the price. I bought for GBP 33. Now they are listed for GBP 36.
