spider Posted June 1 Share Posted June 1 Is it possible to swap the input shaft from a herald 3 rail 3 syncro box into a gt6 3 rail box so that it will fit into my 1360 estate? Many thanks Spider. Link to comment Share on other sites More sharing options...
Nick Jones Posted June 1 Share Posted June 1 No. The gears on the inside are different too. You can use fairly easily use 3 rail gearboxes from Spitfires, plus early 1300 & 1500 Dolomite/Toledo. Single rail from Spit 1500 and later Dolly/Tolly can also be made to fit, but a bit more aggro. Nick Link to comment Share on other sites More sharing options...
spider Posted June 1 Author Share Posted June 1 10 minutes ago, Nick Jones said: No. The gears on the inside are different too. You can use fairly easily use 3 gearboxes from Spitfires, plus early 1300 & 1500 Dolomite/Toledo. Single rail from Spit 1500 and later Dolly/Tolly can also be made to fit, but a bit more aggro. Nick Bugger. Looks like I will have to fit the 1500 single rail box non o/d ( I knew there was a reason I had kept it all these years) and have to source an appropriate length prop. Will be putting a 6 cylinder motor in it at some point as I may as well keep all the mechanicals the same for all my cars. At least I have removed bonnet,engine and gearbox from the GT6, which I am counting as the start of it's restoration that it has been waiting for, for more than 8 yrs. Link to comment Share on other sites More sharing options...
spider Posted June 1 Author Share Posted June 1 ...or can I fit the internals from the 1500 box into the herald 3 rail box? Link to comment Share on other sites More sharing options...
Nick Jones Posted June 1 Share Posted June 1 No. You can fit the guts of a single rail into a 4 synchro 3 rail (though it doesn’t get any shorter), but not the 3 synchro 3 rail, which is what the Herald box should be (square output flange is the giveaway). Link to comment Share on other sites More sharing options...
spider Posted June 2 Author Share Posted June 2 Looks like I have run out of simple , no cost options. So looking for a cheap 3 sync box or go all out and change engine,box,diff,brakes and suspension. Link to comment Share on other sites More sharing options...
