Escadrille Ecosse Posted June 11 Share Posted June 11 Nice country views but like you say. Did like the Imp at the end. Upstaging the cars parked either side of it Where was that? Link to comment Share on other sites More sharing options...
Hamish Posted June 11 Author Share Posted June 11 7 minutes ago, Escadrille Ecosse said: Nice country views but like you say. Did like the Imp at the end. Upstaging the cars parked either side of it Where was that? Tuesday classic cars at swettenham arms thursdays are classic bikes https://swettenhamarms.co.uk/offers/ Link to comment Share on other sites More sharing options...
Hamish Posted June 12 Author Share Posted June 12 Just an aside 3 sisters sprint in Wigan went well not looked to see if I finally got under car video. it was a struggle !! 3 Link to comment Share on other sites More sharing options...
Nick Jones Posted June 12 Share Posted June 12 Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted June 13 Share Posted June 13 Excellent work there sir! Link to comment Share on other sites More sharing options...
Hamish Posted June 13 Author Share Posted June 13 Well you say that !!! I have just looked at the under video - yes it worked video to follow hopefully. However, I made a rookie error and symptomatic of sprinters. I made changes after 1st practice. I had a slippy and tank slapping practice that I put down to tyre pressures too hard. ( rather than a fresh and slippy track) thus looked at tyre pressures - yup harder than my usual set up so lowered them to my usual settings- yup I know you can see what I didn’t at the time !!! tyres are now warm - dropped to cold settings Doh!! and I did the timed runs like this ! this is a screen shot of the video off my laptop as a teaser will try and do an in screen pic or even side by side. thats a 55 profile stiff walled tarmac rally tyre !!!! 1 Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted June 13 Share Posted June 13 Ooooh. This is going to be interesting.... Link to comment Share on other sites More sharing options...
Nick Jones Posted June 13 Share Posted June 13 Well…. Value of camera position already proven. Practical as well as entertaining. That’s some sidewall deflection there! Link to comment Share on other sites More sharing options...
Martin Posted June 13 Share Posted June 13 (edited) Interesting that there is such a flex in 55 race tyre. What pressure was in the tyres? congratulations for such a result , all the work pays out. Edited June 13 by Martin Link to comment Share on other sites More sharing options...
Hamish Posted June 13 Author Share Posted June 13 That’s 23 warm which is about 20/21 cold should be 23 cold which goes to about 27/28 hot. Link to comment Share on other sites More sharing options...
Hamish Posted June 13 Author Share Posted June 13 3 sisters The video 1 Link to comment Share on other sites More sharing options...
Nick Jones Posted June 13 Share Posted June 13 Cracking. Most excellent in all respects. That looks like a great fun track. The car is now noticeably faster and sounds great. Like the extra camera position. 1st in class….. You need to pump the tyres up….. but you know that. I wonder if you might also benefit from a little more negative camber - do you know what you have now? Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted June 14 Share Posted June 14 That was bloody brilliant Hamish. Car sounds superb and going very well indeed. Bit of daylight under the tyre at times It looks like a lot of deflection on that tyre but the there is a LOT of load on the outside front corner and you only have one data point to judge what sort of deflection you should expect. The bit that matters most (with qualifications) is keeping the tyre contact patch flat to the road which it seems to be doing pretty well They do seem to be doing a good job at that so I suspect that you can't be that far off the right pressure for the conditions. Best way of checking tyre pressures other than feel is to check the temperature across the width of the tyre immediately after a run. For a correctly inflated tyre the temp of the middle should be very roughly the same as the average of the outside and inside. A lot cooler and the the tyre is underinflated, a lot hotter overinflated. For camber if the outside of the tyre is running a lot hotter that the inside then more camber is needed. With the caveat that this affects straight line stability. Excessive tyre defection will also affect the inside/outside balance too. Because nothing is simple. The other thing that will be adding to the defection of the tyre is that it is not on the maximum size rim for the width. A wider rim will give a stiffer sidewall response, if a. the car will take a wider rim and b. if you want to spend the not inconsiderable dosh The other thing to bear in mind is that some sidewall flex is also beneficial for 'our' old cars with their less sophisticated suspension geometry both for grip and handling feel where the surface is anything but perfect. Particularly on the road but also for handling track bumps. And then there are heat effects on short hillclimb/sprint events vs longer ones. Sometimes you have to compromise with a slightly softer setup to compensate for starting from cold off the line even if when the tyre is hot towards the end of the run it's perhaps too low. That first 72 feet from the standing start is - all else being equal - where the race is won or lost in a sprint. For comparison running 185/55 Avon ZZR super soft or 185/60 A48s softs on the Spitfire (admitedly quite a bit lighter than the TR and with the swing axle rear) of around 23 psi at the front and 19 psi at the back. So a lot lower than you would expect. Photos showed quite a bit of defection but actual grip was better and the standing 72 foot times were significantly better. 1 Link to comment Share on other sites More sharing options...
Nick Jones Posted June 14 Share Posted June 14 Ignore my gibbering…. Listen to Colin! 1 Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted June 14 Share Posted June 14 The late and very great Alan Staniforth was the font of much of what I know Link to comment Share on other sites More sharing options...
Martin Posted June 14 Share Posted June 14 Brilliant video. Did you notice the strong deflection in the steering or „car behavior“? Link to comment Share on other sites More sharing options...
JohnD Posted June 14 Share Posted June 14 2 hours ago, Escadrille Ecosse said: The late and very great Alan Staniforth was the font of much of what I know St.Alan, please! Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted June 14 Share Posted June 14 1 hour ago, JohnD said: St.Alan, please! Link to comment Share on other sites More sharing options...
Hamish Posted June 14 Author Share Posted June 14 Thanks for your kind words and support as well as the push to get tyre in action footage. I know that it was really to get tyre in air footage but the at least I now know that I need more air pressure and not to use cold pressures on warm tyres!! Link to comment Share on other sites More sharing options...
Hamish Posted June 16 Author Share Posted June 16 Spotted this Mike hawthorn Le Mans video with on board filming and commentary just look at the kit !! them realise the roads are open to all traffic Link to comment Share on other sites More sharing options...
Escadrille Ecosse Posted June 16 Share Posted June 16 Bloody hell....! Where do we start. Just a year after the catastrophy at the pits no seatbelt and that great big metal contraption strapped to your chest 6" from the steering wheel! And all the traffic, on the one hand but also compared to a modern road how little traffic there is. And it's really just a road with all the hazards if you come off (thinking IoM TT here) But what a fantastic bit of film, with Hawthorn doing his own comentary. Thanks Hamish Link to comment Share on other sites More sharing options...
