foshi Posted February 21, 2022 Posted February 21, 2022 hi the bond i acquired came in bits gt4 getting to the point of repaint, any idea what rear screen rubber was used, was it only on the bond or other triumph models . not having much joy finding one paul.
Escadrille Ecosse Posted February 21, 2022 Posted February 21, 2022 Don't know. The screen looks a bit like the GT6 but given that it predates that by a few years it won't be that. The alternative is to get some window rubber moulding and make your own. There a a couple of different profiles available that should do the job. Try these guys https://www.rubbertrim.co.uk/
Nick Jones Posted February 21, 2022 Posted February 21, 2022 Another https://coh-baines.co.uk/ Do you have the old one for comparison?
Hamish Posted February 22, 2022 Posted February 22, 2022 I used these guys to find trim for my 3a hardtop you have to look at everything though as it may be listed differently to what’s fitted https://phoenixtrim.co.uk/contact-us-2-w.asp
foshi Posted February 22, 2022 Author Posted February 22, 2022 problem is i have no old to compare, no idea of profile . wonder if someone has an old bit of gt6 i can try . definitely not the same as front . paul
Escadrille Ecosse Posted February 22, 2022 Posted February 22, 2022 Have you a photo of the window aperture profile??
Nick Jones Posted February 22, 2022 Posted February 22, 2022 Is the screen bigger than the hole or a few mm smaller all round?
GT6Steve Posted February 22, 2022 Posted February 22, 2022 A quick glance thru the Courier archives indicated that the rear glass was a custon spec for Bond
Escadrille Ecosse Posted February 22, 2022 Posted February 22, 2022 3 hours ago, Nick Jones said: Is the screen bigger than the hole or a few mm smaller all round? That's the question I meant to ask
Nick Jones Posted February 22, 2022 Posted February 22, 2022 37 minutes ago, GT6Steve said: A quick glance thru the Courier archives indicated that the rear glass was a custon spec for Bond Yes, and more than one as the GT4S and 2L look very different Yours is the GT4S? Good thing as the seal on that will only need one join, not 4! I reckon that once the profile is identified you could just buy a length and cut/glue as required. Looking at the blue car I reckon the profile could well be the same as the GT6 one. Give COH Baines a ring...... or failing that, someone like Dale at Moordale Motors.
mpbarrett Posted February 23, 2022 Posted February 23, 2022 might be worth asking on the TSSC forum. There is a Bond specialist and a section in the mag just for Bonds. Contact details below (image from magazine PDF).
