Gimmick ? Rev/gear change limiter
Hamish
 Share
I hope this is the right place as I feel there is a not tooo dissimilar association with the OD logic switching thread - that got me started on this Avenue.
as you guys know I destroy gearboxes in my futile attempt at faster times.
I came across this Rev limiter (which I guess would be wise for my new engine) with an added function of reducing the revs with a full throttle gear change.
as I understand you can set the overall engine protection Rev limit eg 6000rpm
but with a switch connected to the clutch you can set another clutch actuated on and off limit eg 4000rpm so you can keep your right foot buried.
Gimmick or useful !
I feel it would be an unnatural thing to re-learn as we all have that foot automated reaction to lift and plant again through a gear change
https://www.demon-tweeks.com/uk/armtech-panel-mounted-rev-limiter-with-full-throttle-gearshift-240115/
On 9/12/2021 at 11:35 AM, Hamish said:
Gimmick or useful !
I can't comment on the Gimmickness/Usefulness, however I can't help but suspect the re-learning  the gear change might be deceptively easy.
Probably to the detriment of every other manual box car you drive!!
 Share
