Spitfire 1500 windscreen
hardhatharry
Can't comment on the screen itself as we have only refitted old ones but we did have significant problems fitting the screen to our Spitfire using Paddock supplied rubbers.  We tried two.  One was 20mm mm longer than the other, and even the shorter one was too.  Even after cutting and gluing the longer one to what  I thought was correct (around 30mm removed!) it still wouldn't sit right in the corners.
Finally bought one from COH Baines (on the advice of Dale of Moordale motors who reckons these are the only ones that fit properly) and problem solved.  Used the same on the GT6 and that is also fine.
So, COH Baines FTW!
