vitesse loom
foshi
hi i need to remove the complete loom  from my donor  vitesse   still has the dash installed  then transfer it into my current project vitesse what is     best procedure, do i start from the engine bay and work back ? paul
Front and rear looms are split.  There is a plug under the dash on the LH A pillar.  Otherwise yes, just work from the front back starting where the headlight wiring plugs into the bonnet loom.  You can feed that back through the holes on the bulkhead.  Might then be easier to remove the complete dash assembly.  If it's a convertible, feeding the rear loom through the hole in the LH hood bin is a pain.... and has to be done from the back forwards as the plug under the dash is way too big to go through the hole.
