My airbox thoughts were as follows.
In theory a big volume (you are limited with what you can do between carbs and wheelarch) will make it a neutral point, which means it becomes the starting point for the really complex induction stuff where you consider pulses and velocities when you need to really consider the momentum of air.
This big airbox is fed by a big tube with a massive cone filter, aiming to minimise any pressure drop between the airbox and atmosphere.  A big cone filter is mounted in front of the radiator so pulls coldest possible air.  This allows you to select a big cheap air filter.  there are many arguments about filter pressure drop vs filtration performance and power etc. etc.  Increasing your filtration area is relatively cheap way to get the best possible outcome.  No way is a K&N developing less pressure drop than a paper filter with 10x the filtration area!
I think I have 3" tubing which looks comically large, but matches the ebay K&N cone I got for peanuts.
Also a 1.3l engine at 6.5k is breathing 70 l/second (assuming 100% volumetric efficiency), or the air going down that path is traveling at 16m/s or 35 mph (feel free to validate my calculations, I got a bit confused at one point, but I think I'm right). The original airbox hoses are about 1" and although there are two, the air is going about twice that speed.  To be clear, the presure drop on this component is likely still peanuts compared to what's happening in the inlet manifold, head around the valves, etc. so is unlikely to be the limiting factor, but it's a relatively easy thing to make better.
The main issues with my working prototype are:
it rubs on the inner wheel arch, not a big issue as it means I've maximised the volume available there.
It's tight around the radiator brace and radiator so hard left lock means the front of the drivers tire does abrade the inlet tube.  I'm looking at re-routing under the radiator where there's possibly more space, making a new radiator support to give more clearance, and/or making an oval tube to link the airbox to the filter.
I've misplaced the photos of my airbox, I think there are some on here though.
  • Thanks 1
I have also pondered on airbox design and I previously posted this on the TSSC forum at https://forum.tssc.org.uk/topic/12397-air-filter-question/page/2/#comment-195288
My current thinking regarding the airbox as described within the post above. The large diameter (circa 70mm) single pipe is  achieved by flaring out the box at the front end where the wheel arch allows.
If I make it the right depth it can use either my existing K&N filter elements, or a remote filter at the side of the radiator.
Ian
This looks great! Much more craftsmanship than in mine, also I think it has a narrower radiator than my spitfire.
In a money no object redesign I'd try a narrower aluminium radiator (with integrated oil cooler) to make more space for this kind of air feedfrom the front.  It's a much more constricted area than I first realised.
I think I might have seen these pictures across my searches, it was a tight fit! This is the problem on the gt6, a bigger airbox is more desirable but is all down to space. I think this is one of those problems I wanted to solve early, but in reality not going to be able to until I can physically see what sort of room I have to play with in situ. Especially running larger carbs, fortunately without those crappy tt adapter plates for the hs6's thst push them so far back they might as well be outside the car!
I know what you mean with the tubing, it's very bumpy and not at all the best thing to use, the smoother larger pipe is a much better solution as you've found. I'm definitely in favour of this route, I think the results it will yield are definitely going to be better than just slapping some bank breaking k&n pancakes on and calling it job done.
Ian
Ian, that's a proper template! The foam is the right way to mock it up, especially with the space limits. That's a extreme close between the arch, nice job!
Thanks for the help on the boxes guys, I think it's one of those issues I need to solve with the engine back in the car. Not too far away hopefully.
The aim was to get the car back on the road for the summer but summer seems to have gone. Anyway, the target is late August at the moment so it's quite an uphill battle!
Smoothed out the manifold ports over the weekend, some very large steps and poor machining from the factory, I corrected them without enlarging the port dia using a 60 grit sanding bit on the die grinder.
20240715_124417.thumb.jpg.ef3852acbae17eae85ee5047be9daf4d.jpg20240715_124430.thumb.jpg.53664332aadbb3788442aa11927d4f8a.jpg
You can't see it that well but the flat head of the screwdriver doesn't run smoothly up any of them and goes in about 1mm in some spots. Hopefully this has some sort of effect:laugh:
I re checked the chamber volumes and gave an average of 34.08cc. So slight increase from before from the cleaning, or just measuring properly this time.
With that it yields a current CR of 9.38:1. Not what we want. So working backwards. I was aiming between 9.5-9.6. Before the target was 9.5, however given this time it's cemented in that we're running a hotter cam, flowed head and slightly improved flow (hopefully), tubular manifold and both port matched to the head( yet to be done) etc, as well as lots else done with the aim of improving the performance, I think 9.6 might be OK.....
Anyway, if we run 9.6;
337.62/(9.6-1)=39.26
New chamber volume=39.26-3.5-2.7
=33.05cc
I have the head setup perfectly level to do it the burette way and measure with a flat edge and digital verniers. My only concern, does anyone know the minimum thickness these heads can go? Really don't want to punch into a water jacket after all this time and effort.
Just measured the depth, quite fiddly but end up with a figure of 0.030, 30 thou basically, firs measurement I did came at 0.023, then rechecked and got 0.030.
Current head thickness is also sat at 3.339"
Managed to get a few bits done over the weekend, my new wipers finally arrived!
Took a little bit of searching but NOS came in at 5 quid more than a pair from rimmer or canley of the modern type ones. My wiper arms needed a touch filing off them to fit these, hopefully they are an improvement!
The port matching is now complete! Simply used a manifold gasket with all the studs in place
the left is factory, the right is after. Some required quite large amounts taking off, definitely restrictive. Didn't enjoy it either doing it in a full face mask on the hottest day of the year so far, was a very sweaty experience. The manifold I recently acquired matched the gasket I'd say 95%, some had a small amount on the lower edge but given it has a mm or so of movement before its tightened on the studs, I decided to leave it.
The last job which I didn't photograph was removing the square water take off plug from the head, my God that was frustrating. Spent about an hour, eventually got it off by hammering the square end of a socket reducer on to what was left and using the air impact to ease it off. Removed all the guides too so the head is now ready to go to the machine shop when funds permit.
Jacob
Jacob
That's similar to what I found when I did mine. I suppose if the casting and machining is the same it would be.
Bit sloppy Mr Triumph!
Ian
  • Haha 1
Ian
Not quite modern day standards:laugh: Everything seems like it had the that'll do approach!
47 minutes ago, RedRooster said:
IMAG2235.thumb.jpg.8798417fb1e566f65ecb4a32d7a910a1.jpgDHLAs are the way forward :thumbsup:
If only the budget allowed! I'm going to squeeze every horse out of this boat anchor without going tripple carb:laugh:
Very good power can be made on a pair of carbs. I know a certain french blue T2000 that makes something around 200bhp on a pair of 1 3/4 SUs. Well known in Triumph circles, and it really is quick. Needs to be revved though.
  • Like 2
  • 5 months later...
Afternoon All, it's nice to be back after a bit of a unwanted break abroad for the padt few months! It's nice to be back in the garage and with a bit of time off I can finally get around to doing some jobs on the GT6, target is late Jan for going back on the road, or at least running!
Lots of jobs to get done, the first over the festive period was to finally sort the paint on the car out, it's been fading and fading and really needed bring back to life, so a few days with the machine polisher, I think it's looking much better
20250102_143357.thumb.jpg.226528e3efb0b76a6922d81e924e8b35.jpg20250102_143901.thumb.jpg.cb585361120a08a41ff03d5287117f2d.jpg
I cant wait to get some pictures in the sunlight, the lighting in the garage is not the best. But i assure you, its like a mirror.
I spoke to Newman cams before Christmas and ordered a new cam for the block, The chap there tried to sell me the TRI6 profile, but I stuck to the tr5 35 65 cam. I hope they provide the data sheet with the magic number for timing it in, but seeing as it's a standard factory profile, I should be able to time it the normal way a factory cam gets done?
Anyway, cam is on its way and the head will go off to the machine shop next week when they reopen. I'll post some pics as they come out!
Last bit of paint attention on the car to sort before then is this lovely area
Was all bubbled up, typical spot on the mk2s, I'm going to have to flat that bottom lip, prime and use some tiger sealed for the seam, then blend with the paint. Not fun, but could be worse.
Nothing huge to report today, unwrapped the engine that's been sitting on the stand since the summer and installed the front plate with some nice new ss bolts.
I may have a cam tomorrow! Newman have sent it today so may well see it tomorrow, absolutely dreading timing it in. Am I right in saying that the timing for the 35 65 cam is 105°atdc on no1 inlet? I don't think they'll provide me a data sheet with the number on it.
We shall see tomorrow!
2 minutes ago, Escadrille Ecosse said:
Works well in the 2L in my experience.
I'm looking foward to seeing the improvements. And with all the little extra bits I've been doing along the way, I really hope for some noticable improvements
If we are thinking of the same car Clive, it was running (1.5") HS4 carbs on an HS6 inlet manifold.
I saw this during a RBRR whilst the fluid levels were being checked at John o' Groats.
For a mark two engine, the HS6 manifold has the longest runners.
Some people have used 1.5" Strombergs on this manifold as well.
Ian.
Jacob
I have never had any joy with they NOS original type blades, Jacob.
My (now sadly deceased ) next door neighbour accidentally bought 35cm original Fiat blades
(which were for various tailgates during the naughties)
but he had meant to get front ones but the low price on ebay was too tempting.......
so he asked if I could use them.
I was able to extract the refills and use them on my Dolomite...
and this gave really very good rain water removal :cool:.
Ian
Ian
I have found GSF own brand wipers to be pretty good on dolomites, last a year, and cheap. Trouble is teh new plastic clips are not very good, so best to keep the old ones (and any spares)
Usefully I discovered that LHD mini wiper arms are available with modern hook ends, and are a perfect fit on spitfires/heralds/vitesse. The "downside" is they are only available in black.
  • Thanks 1
The TR5 cam is symmetrical so you  time it the same way as all the other works cams. You don't actually need an install degree.
