steveJM Posted October 1, 2020 Author Posted October 1, 2020 Ohhhh. I didn't pick up on that... thought the chassis mounts were used.
steveJM Posted October 1, 2020 Author Posted October 1, 2020 Nick. Ooops had no idea they moved the guides for rotoflex. Anyone have pics that show where they are.? I gather ill have to cut off existing and reattach...
Nick Jones Posted October 1, 2020 Posted October 1, 2020 I’ll see if I had some pics. When we did the Spit we were lucky enough to have the necessary section of floor complete with guides from a GT6. Obviously this was cheating....
Nick Jones Posted October 2, 2020 Posted October 2, 2020 Some pics from the GT6. Not great ones unfortunately. Still hunting on the Spit. I'm sure we did add them but can't find pics to prove it at this point....
steveJM Posted October 15, 2020 Author Posted October 15, 2020 Thanks Nick, Will get back to that latter and add to tub. got my Chassis and parts back pretty quickly, despite being out of action for a number of weeks, some progress. hmmm pic not loading?
Nick Jones Posted October 16, 2020 Posted October 16, 2020 8 hours ago, steveJM said: hmmm pic not loading? Should be fixed now
Nick Jones Posted October 16, 2020 Posted October 16, 2020 Coming together...... and looking pretty complete mechanically. Is that your proposed new handbrake cable guide? Or the original? Doesn’t look like the original.....
PeteStupps Posted October 17, 2020 Posted October 17, 2020 On 10/16/2020 at 9:26 AM, steveJM said: Ace! That motor looks like it means business
steveJM Posted October 19, 2020 Author Posted October 19, 2020 On 10/16/2020 at 11:13 PM, Nick Jones said: Is that your proposed new handbrake cable guide? Or the original? Doesn’t look like the original..... Handbrake cable was installed prior to axles & spring, and discovering my error...impossible to remove now... so will cut off rather than dismantle rear suspension. and Yes, Is the original Spit 1500 cable guide with GT6 roto cable... FYI according to rimmer Roto cable 137mm in length. I'm still pondering to use existing Spit cable guides and making shorter cable. or to fab cable guide and attache to body tub as per GT6 set up... and get new GT6 roto cable. difference in arc seems minimal ...
steveJM Posted February 23, 2021 Author Posted February 23, 2021 (edited) Been on the go slow, last few months. ... But some progress, Firstly decided to upgrade brakes at front to the BCC. good option for me (despite the cost) fits TR7 wheels, less weight, 4 pot should be better than old 2 pot...? especially with some extra weight onboard. decided to make bracket to have Flex hoses in U rather than S ... not sure if it is the right thing to do, but looked better to me... only slight mod to the dust shield, left one trimmed, Right to do.! Ears were removed and bent a new but slightly smaller.. Edited February 23, 2021 by steveJM spelling error
steveJM Posted February 23, 2021 Author Posted February 23, 2021 Spent too much time designing my HV contactor / box.... & fitting coolant header tank
steveJM Posted February 23, 2021 Author Posted February 23, 2021 (edited) Now building up my battery boxes. Old... Engine Position... Front Pack... Edited February 23, 2021 by steveJM
Nick Jones Posted February 23, 2021 Posted February 23, 2021 Great to see progress. Interesting about the brakes. Somehow I appear to have missed BCC up to now........ Presumably your extra weight (minimal hopefully?) will also be offset by having regen braking available? Now the fiddly part - finding homes for everything and executing it tidily. There is clearly lots of work in the battery racking. To my eye that looks like lot of batteries hung way out front.... but I guess that this is just the "first wave" and there will be plenty of others distributed around the car. How many cells in total? (count 36 at the front). Coolant?! Ah, yes, liquid cooled motor......
spitfire6 Posted February 23, 2021 Posted February 23, 2021 Hi, Very nice all round Steve. Are you using a pre-charge resistor for the Inverter? What BMS are you using? Will this ultimately control the charge/regen & discharge contactors? Are you having a charger onboard or charging with HVDC? I might have a 500VDC 7KW heater destined for skip or good home. (Porsche). Cheers, Iain.
steveJM Posted February 23, 2021 Author Posted February 23, 2021 (edited) Hi nick Battery pack. Is relatively small for ev.. 25kwh about 150klm range. But is high voltage 350v so to achieve v i need 108 batteries. Maybe 96 if too heavy. Aiming to be 40kg over. Which is well within the GVW . Can not exceed that in Australia... to keep it simple avoid engineering report etc. 36 pack over original Radiator pos' 24 pack goes where the engine block was 24 pack in replace of fuel tank. 24 pack in boot up against fuel tank-pack Edited March 19, 2021 by steveJM
steveJM Posted February 23, 2021 Author Posted February 23, 2021 Bms is zeva made in Australia Evms3 version. Wiring up is next on the list, partly there... Bms has built in precharge resistor and you can see i have 2 HV contactors one will be connected to precharge. The charger is a small 3.3kw elcon CAN controlled by the BMS. Charger is located under the front battery pack next to coolant pump. Can be seen in earlier pics. Still not worked out where to put inlet yet... Regen will be controlled by motor controller gevcu for uqm motor & inverter. Along with And brake pressure switch from hydraulics. Im sure that would be a good heater... I have heater sorted... more just for mot as you call it. Requirement in Australia. Ready for assembly. I Opted for minimalist approach. 12v ceramic heater in original spitfire heater where radiators were. Will send pics when assembling. Should be fine in Melbourne.. have 2 x 200w. Am planning to have in parallel (total 400w) for high temp switch to series 200w for low temp. But also need its own power supply. Which was an oversight from original plans. But all ver low weight.
BiTurbo228 Posted February 23, 2021 Posted February 23, 2021 I'll be fascinated to see how this comes out weight wise. Distribution would be interesting to know as well...
steveJM Posted May 3, 2021 Author Posted May 3, 2021 Been tinkering around mainly with wiring BMS to each battery in front packs (60 in total). Also now crimped a few HV cables to join the 2 front packs. But have now moved onto the Body. Thanks Nick for the pics of the Handbrake guides for rotoflex. Have managed to make something i think is Close enough. But i have a question for any one out there with a Rotoflex. I'm concerned with the Hand brake cable length if i don't get the width correct when i weld them in. I'm thinking the cables would be 5" apart going into the guides. Is any one able to confirm for me ?
Nick Jones Posted May 3, 2021 Posted May 3, 2021 Guides look convincing. I’ll jack the GT6 up and crawl under with a tape measure if no one else pipes up......
steveJM Posted May 27, 2021 Author Posted May 27, 2021 I got dimension 4.25" if anyone interested Thanks
Nick Jones Posted May 27, 2021 Posted May 27, 2021 Sorry Steve, promised to check this for you ages ago and forgot..... .....so popped the GT6 up in the air just now and crawled under with a short, flexible ruler. Access and visibility aren’t great with the diff in situ, but I got 4.5” between cable centres at the point of entry to the guides. This is an original Roto car.....
steveJM Posted May 27, 2021 Author Posted May 27, 2021 thanks nick. I'll go with yours. will weld in place today!
mk2vitesses Posted December 12, 2021 Posted December 12, 2021 On 10/1/2020 at 9:34 AM, steveJM said: Nick. Ooops had no idea they moved the guides for rotoflex. Anyone have pics that show where they are.? I gather ill have to cut off existing and reattach... If the rotoflex couplings are replaced with CV joints it won't be an issue.
Nick Jones Posted December 12, 2021 Posted December 12, 2021 1 hour ago, mk2vitesses said: If the rotoflex couplings are replaced with CV joints it won't be an issue. My experience says otherwise unfortunately. You get considerable “self-adjustment” with changing ride height. Too much to live with I found. Handbrake comes on as you load up, in effect.
