michaeljf Posted January 15, 2021 Author Posted January 15, 2021 Hello Nick, The original wheels will actually be an inch wider when I am finished with them, the white basket things (Compomotive) are off a rally car ( sons Very radical Datsun "1600"(2000 T/C 2x50mm twin throat carby's) dog box,R200 diff, ohlins coil over all round, full FIA cage, etc. "classic class", they are the heaviest and maybe the strongest and he has 10 of them. The BBS are the lightest by far AND the widest (6.5x15). The white baskets would be only very temporary use IF I don't get the steels finished in time. Regards, Michael.
michaeljf Posted January 20, 2021 Author Posted January 20, 2021 Hello Nick, The original wheels will actually be an inch wider when I am finished with them, the white basket things (Compomotive) are off a rally car ( sons Very radical Datsun "1600"(2000 T/C 2x50mm twin throat carby's) dog box,R200 diff, ohlins coil over all round, full FIA cage, etc. "classic class", they are the heaviest and maybe the strongest and he has 10 of them. The BBS are the lightest by far AND the widest (6.5x15). The white baskets would be only very temporary use IF I don't get the steels finished in time. Regards, Michael.
michaeljf Posted January 20, 2021 Author Posted January 20, 2021 Hello, Don't know what happened there. Anyway here is the photo of wheel (you might notice there is no brake drum behind it). Regards, Michael.
michaeljf Posted January 22, 2021 Author Posted January 22, 2021 Hello, Oh and I painted the BLACK, they were silver originally. Regards, Michael. The last couple of times that I have gone to send a reply the previous message has been in the reply box! (That's what happened above)
Nick Jones Posted January 22, 2021 Posted January 22, 2021 I like the wheels and I like the black centres
Hamish Posted January 24, 2021 Posted January 24, 2021 I admit I went with the cheaper option of the minilite copies for my 3a my road tyres (very wet track days) are silver vredestiens sprint classic 185/70x15 my race (sprint and hillclimb road legal) tyres 185/55x15 are black with cut silver rim i have just bought another set that have just been painted black for a used set of Avon cr6zz 185/89x15 tyres road legal but intended for higher speed tracks like aintree. I changed to 4.1 diff so with 55 profile tyres a loose a lot of top speed which isn’t a problem as most sprints and hill climbs. the 70 profile help the speed a bit but loose some stability on the corners.
michaeljf Posted January 28, 2021 Author Posted January 28, 2021 Hello Hamish, All look good. Have you used the Maxsport yet? I have a friend who runs a TR3a in group Sa, will post a photo and a few specs. somewhere. Regards, Michael.
Hamish Posted January 28, 2021 Posted January 28, 2021 17 hours ago, michaeljf said: Hello Hamish, All look good. Have you used the Maxsport yet? I have a friend who runs a TR3a in group Sa, will post a photo and a few specs. somewhere. Regards, Michael. Yes I have done 3 ? Seasons on the maxsport the soft compound. Sprints and hillclimbs. Very pleased with them. Curborough fig 8 sprint is about 79 s on road tyres to 73s with maxsport 6 seconds in just over minute run is a big chunk of time. the soft wouldn’t last on a circuit of a few laps.
michaeljf Posted February 1, 2021 Author Posted February 1, 2021 Hello, Back at it ,might have got the rockers sorted, will check the "lash" in the morning, then if all well will be ordering the new chrome moly pushrods, check if rocker cover clears, new rocker stud bolts, possible new rocker cover bolts etc. Regards, Michael.
michaeljf Posted February 2, 2021 Author Posted February 2, 2021 Hello, The steps back! The tech.instrument supplier supplied the wrong size (thread) extensions for the dial gauge so plan B. Regards, Michael.
michaeljf Posted February 4, 2021 Author Posted February 4, 2021 Hello Hamish, I bought them s/h, were supposed to be 1:6 but with measuring seem to be 1:64 and made in Sydney. Have been having trouble (know nothing about roller rockers) working out shims for posts then pushrods. But may have now.... Regards, Michael. (what do you think of my wife's effort on the little round picture?)
michaeljf Posted February 5, 2021 Author Posted February 5, 2021 Hello, This is where I found some information on the rockers (good, bad or otherwise?) www.flowspeed.com/harland-sharp.htm Regards, Michael.
Nick Jones Posted February 6, 2021 Posted February 6, 2021 Nice avatar Are you going to need a power bulge on your rocker cover to clear those rockers?
michaeljf Posted February 6, 2021 Author Posted February 6, 2021 Hello Nick, Yes, was going to cut two rocker covers (one a bit taller) and join them! (then the studs will be extended too) Is the "avatar" the Laverda and me? Regards, Michael.
michaeljf Posted February 6, 2021 Author Posted February 6, 2021 Oh, Laverda = 1000cc, 3cyl.,120 degree crank, Italian. 120,000+ kms. 30 odd years. Regards, Michael.
michaeljf Posted February 11, 2021 Author Posted February 11, 2021 Hello, I have had someone else check the formula's and came up with the same interpretation as I did so will see what we arrive at with the valve "lash" and timing tomorrow! Regards, Michael. (roller rocker set up)
michaeljf Posted February 18, 2021 Author Posted February 18, 2021 Hello, Well a little progress (step forward). Happy with valve lash and ordered new chrome moly pushrods in the right length, new (longer ) rocker gear studs, length of 12mm alloy strip to make rocker cover spacer, timing chain /vernier cam gear /timing etc., done and new bolts to turn into rocker cover studs (longer). Photo tomorrow? Regards, Michael. Have had my brother with the damaged hand visiting for a few days and he has got me moving on the motor.
michaeljf Posted February 22, 2021 Author Posted February 22, 2021 Hello, photo will say most of it. waiting for 12x12 mm alloy strip ( for rocker cover spacer). Have to make a couple of gaskets (big bore one for manifold) collector for extractors. regards, Michael.
michaeljf Posted February 22, 2021 Author Posted February 22, 2021 Hello Nick, Finally, some small bits, then THE axles. Oh I am also going to try and move the motor about 32mm rearwards and about 10 mm lower..... will see how it looks when it's all united. Regards, Michael.
michaeljf Posted February 24, 2021 Author Posted February 24, 2021 Hello, Spoke to the man making the pushrods (in Melbourne) today and he says they will be made by the end of the week. How do you like the bracket for the alternator? The other picture is the original head. Regards, Michael.
Nick Jones Posted February 24, 2021 Posted February 24, 2021 Alternator bracket seems to have been on a serious diet...... Looks like a proper MikeThePipe 6-3-1 manifold in the second pic
michaeljf Posted February 24, 2021 Author Posted February 24, 2021 Hello Nick, Yes, serious enough to turn it into an anemic colour. Pipes were given to me by a SERIOUS racer but need some serious work! Regards, Michael.
Chris W Posted February 25, 2021 Posted February 25, 2021 Hi Michael, Great thread you have going here. Could I ask what you have done to delete the fan extension? I've seen kits available from the States but nothing in the UK. I appreciate you are in OZ so did you machine something yourself? Cheers Chris
