1976 Triumph Spitfire Build thread
  • Replies 216
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
More progress today finally glued the rear wing on and sorted out some missing metal on the bottom of the door recess, a momentous occasion the last time this spitfire had a driver rear wing was 1993.
Stick 'em on ebay - they could be worth more that the Spit to one of those avid collector types. After all, they must be as rare as Kurt Cobain guitars and those are fetching millions... Paul
I must admit this thread has had me doubting myself even though I know someone with a late Mk4 head on a 1500 with a non standard cam who says it goes great. Looking at the chart a Mk4 head will give
Posted Images
11 hours ago, Escadrille Ecosse said:
This is the point where the volume of the car seems to expand exponentially!
Get ready to fill the loft and then wonder where it all came from, more so when the car is back on the road and the loft is still half full of car!
  • 3 weeks later...
  • 3 months later...
That actually looks quite good.  Or at least better than any of ours were!  Yes, it's gone along the front edge, but round the headlights is good - and the front edge is fairly easy to fix.  What the support structure underneath like?
Bootlid looks good as does the passenger door.  Drivers door more of a challenge.  Could be repaired - or re-skin.
Not too bad, it required a new strengthener
Also reskinned the drivers door and brassed braised for the first time.
Unfortunately I didnt take a picture of the completed bonnet but you can see it in the back ground. Put everything into etch primer ready for putting some of it back on the carIMG_20201017_165648.thumb.jpg.b49caad82553eb70bccf33509d0f2178.jpgIMG_20200912_161955.thumb.jpg.105ee4dbb2ba0942d5a4d874fce972d9.jpg
Unfortunately I ran out of gas before I could weld the outer wing, so that will be this weekends task.
Then its the great interior strip down in preparation to put the body on the rotisserie and work on the floor which isnt too bad and check out the chassis.
Also done well on the eBay side too.
A set of adjustable Spax shocks which although they were fitted to a car were never used, need a bit of paint but everything works £43 and a set of Hel braided lines for £20
So adjustable shocks all round for the cost on 1 new shock.... result.
Currently searching for a cheap set of lowering springs2017141163_BraidedlinesSpit.thumb.jpg.dd1af7d307221d6615dac817d7f5cfa5.jpg1481644320_SpaxShocks.thumb.jpg.3df628f11063a014c80a4938818e9b41.jpg
Anyone know if these will do the job, I was looking for a 1" drop and I believe 7 1/4" may work so this would just need a spacer their springs lengths increase in 1" steps, they also do a heavier weight (they seem to go up in 50 lbs weights)
COIL OVER SPRING 7" - 2.25 X 350LB £24 each spring
A little more done this morning while it chucks it down with rain.
Knowing that the boot lid is a place that attracts rot I have covered the underside with Hydrate 8
I have also taken the paint of the passenger side door hinges and painted then in primer.
My driveway is quite steep and a few weeks ago I nearly lost the spitfire down the drive which could have been a disaster so I have been on the hunt for a winch.
I picked one up last week and the pictures didn't do it justice, I currently figuring out how to mount it. It has 30 metres of 6 tonne rating strap.
That it a pretty substantial winch!
The door bracing bars don't need to be enormous. I have used Dexion in the past. Done the job fine.
I do recommend though that you put in a triangle to stop the bulkhead end from closing and dropping. Bar straight across near the top and a diagonal bottom back to meet top front.
IMG_20201025_111251.thumb.jpg.34a7418792a8369745b02300978cdfbb.jpgIMG_20201025_120438.thumb.jpg.23bb2f3f84477350f7dcb50ab91fdb30.jpgIMG_20201025_131110.thumb.jpg.b7683c96fba7c0e412c44052e196d287.jpg
Also fitted the passenger door on and put a coat of paint on the bottom of the boot lid.
  • Like 2
