I was in Halfords today, and noted their current special offer on tool sets, spanners and sockets, that are "half price". They are the " Advanced" brand, and may be good value to someone.   This is the biggest set.   ... Can't insert a pic I took with this f$¢^°=={ phone!
Anyway
That's it, Nick.     The largest set on offer.       Loaded with some tiny sockets that surely one would never use, so a smaller, cheaper one might be better value, but still a bargain IMHO.
This is a great set
I bought one a few years ago. Nice to get a good range of imperial sockets. I use the smaller sockets on the jubilee clips etc. there are also a selection of impact sockets (mm)
I have their imperial spanner set too.its good stuff.
Edited by Hamish
                 Now I am drooling but I have enough sockets and Spanners to last a life time
Boys and Toys?
ps I still have not put any tools in the new tool chest I bought months ago as I can not find a space to put it! (I feel the need for another garage coming on?)
Back to Boys and Toys????
  • 3 years later...
Have I posted before about tool porn?   The desire to own esoteric tools  that are proper engineers' instruments?  Even when they will NEVER be used?
Such a collection is now on sale:
The contents of a wall mounted rack of tools, measuring equipment & more
WOW!  That biggest micrometer must be at least four feet across!   And the calipers are so big you could deliver a baby with them!
The rest are fairly routine, but I could have used that large tap wrench doing my slave cylinder helicoiling!
PS  The same sale includes this lot:
Quantity of assorted measuring devices, mostly each in their own individual case. This lot comprise
I recognise some depth gauges, but what are all those instruments with a thick ring as part of the set?  JD
I've seen bore gauges, where you lock a spring loaded device set across the bore, take it out and then use an external micrometer to measure that.     So these, does the gauge sit vertically in the bore and extend some sort of arm(s) to touch the sides?
Ah ha!    Found a pic of setting one, using said check ring:
See the source image
Thank you!
  • 3 weeks later...
Just to give you an update, less than 24 hours before the end of this auction, the large micrometer with other odd tools has been bid up to £20
But another lot, of large and VERY large micrometers has got up to £30, which given that they are both still in their boxes with accessories, may be a long way from where the final bid rests.
2 very large micrometers each including its own case - Image 1 of 9
The collection of bore gauges is now at £110 and since there are more than 25 instruments in the lot even that seems quite a bargain.    Since a tri bore gauge, new, is at least £300, that too may rise further.     But I shall resist temptation, since I have little need for such sophisticated precision gear!
More remarkably is a lot of two "precision levels", which have reached £45.      I was tempted, as the weakness of the new ELoO  method I reported earlier lay in the tiny spirit level in my adjustable set square.   One of them looks like this:
2 off precision levels each in their own case/box - Image 2 of 4
As I have a real use for such a tool - instrument! - I am tempted to pursue it, but the above resembles a Starret level I find new on sale at£350!  So probably this will go for a lot more.
Has anyone experience of digital levels?  Either in the form of a spirit level, or a "Level Box", like this, that you can buy new for about £20.
They typically claim a resolution of 0.1 degrees, which has to be better than eyeing a bubble.   The question might be the slope of the cam as the two valves open and close together.  What would the effect be of 0.1 degree on levelling the two lifters?   How far from truly level at TDC, so that the cam was correctly set?   Have to think about that, and look at my cam measuring data, to see if I can work that out.
I’ve got a couple of those level boxes. One I bought (it was more than £20, but not much more) and the other (used) I was given soon after (typical).
They both work nicely.
Not personally, but the phrase "Make the noise" immediately springs to mind, which is pretty reasonable endorsement in its own right?
Yes, indeed, Phil, Project Binky used their digital level that "made the noise" with pride, repeatedly showing the precision of their work! I need to be able to show that the two cams are raised, one going up, one going down, and level.  The top of the block or head won't be horizontal, it slopes back, but if they are parallel to that, they are level!  The 'zero' button can fix that!
Maybe, in good Project Binky style, a bracket to hold the Level Box on the rockers?
That auction has ended, and I think I was right not to pursue those rather attractive lots!
The two precision levels went for £85.
The two giant micrometers went for £180.    Still cheap, I think, but a lot more than I would spend on a unique wall decoration!
And the collection of bore gauges were knocked down for as little as £1080!     That's a tenth of their cost new, so probably a bargain for somebody, lets hope an engineer, not a set designer!
  • 2 months later...
As mentioned elsewhere I finally got to the stage of replacing the two bent exhaust valves on the Scimitar V8.
This then entailed some light grinding of the valves/seats. Dug out the gringing paste and valve tool which did the job admirably using just some of the fine grinding paste.
I realised that these two specific items, the grinding paste and valve tool, have been used for every cylinder head job I have done on one of my own cars. Which is a few.
Starting with my first, a 1972 Hillman Avenger 1500DL estate in 'prairie wind' (dust bowl beige). Which would have been around 1980 or so.
Don't know how much the valve tool cost but the grinding paste was £1.31, money well spent in the Falkirk branch of Halfords all those years ago.
The tin has a lid at each end. One end coarse the other fine with a divider in between.
Colin,
Forgive me if I advise egg sucking!  Does the Scimitar have alloy heads?    Then it will have steel inserts for the valve seats - fine.
If it has iron heads, and no steel inserts, then you may have removed any 'lead memory' and the new valves may erode the seats.
Hi John. No worries :biggrin:
The Rover V8 is all alloy with inserts.
Having said that the head on the Spitfire has hard inserts too. Been so long since lead was available that any memory effects are long gone.
Not shy of using full throttle or the rev limiter. :devil:
             Whats with all this New Stuff?
This is mine (I do have a stick with suckers on the end but the 50/60 year old rubber has got cracks in it!)
The Tee wrenches are Terry's one is 5/16" and one 3/8" so just about right
The Clover paste and Micrometer blue I know are at least 55years old as I borrowed them from a place I worked at!
  • 2 months later...
Another Sykes Pickavant tool bought from Halfords a few thousand years ago. Used very rarely, can't actually remember the last time but it must have been quite a while as the first job after finding the thing at the back of the tool cabinet was cleaning out all the fluff and crud.
However perfect for when you do need it as in this case...
:confused: Um……. Please sir…. What is it?
I should probably know, but I don’t. Managed 55 years without one.  Not even sure if the spark plug in relevant or for scale…. “Insert embarrassed emoji here”
