Nick Jones Posted April 27, 2022 Posted April 27, 2022 Sounds like you are making strong progress and a win is in sight It certainly sounds fierce!
Martin Posted April 28, 2022 Author Posted April 28, 2022 The Distributors have different advance Springs and weights. I Plan to take the lightest weight for a first atempt. Megajolt?
Nick Jones Posted April 28, 2022 Posted April 28, 2022 2 hours ago, Martin said: The Distributors have different advance Springs and weights. I Plan to take the lightest weight for a first atempt. Megajolt? Megajolt, or something like it is the best answer (if TUV allows?) but not the easiest or cheapest. Or is it possible to get this distributor with a version of the 123-Tune inside it? What shape curve do you want to have?
Martin Posted April 28, 2022 Author Posted April 28, 2022 123 Dizzy is available, but at a price. 600 Euro. So try and error? Getting the curve starting from around 5 degrees at idle. Then 12 .. 15 degrees Up to 4000 , ending up with 30 degrees above 5000.
Nick Jones Posted April 28, 2022 Posted April 28, 2022 20 minutes ago, Martin said: 600 Euro. Thoroughly unreasonable! Are you aware of this? http://www.aldonamethyst.co.uk/ No personal experience, but it looks like it could do what you need and not quite so expensive
Nick Jones Posted April 28, 2022 Posted April 28, 2022 24 minutes ago, Martin said: Then 12 .. 15 degrees Up to 4000 , ending up with 30 degrees above 5000. Light weight, strong spring for the second stage then......
Martin Posted April 29, 2022 Author Posted April 29, 2022 I know the Aldon device. I still have an Accusparc programmable ignition. Runs on Win 7 Asked Accuspark already whether a programm for Win 10 is available. Had it for the Mini of my son, but now unused on the shelf. Perhaps I will lighten the weights with a drill first
thebrookster Posted April 29, 2022 Posted April 29, 2022 7 hours ago, Martin said: Runs on Win 7 Asked Accuspark already whether a programm for Win 10 is available. I take it you have tried installing it on your Win10 machine, using the option to run as Win 7? It's a while since I last tried this but I seem to recall it worked for whatever I was doing at the time? Apologies if you are already ahead of me btw!
Martin Posted May 15, 2022 Author Posted May 15, 2022 After playing with various Jets, ignition timing and tweaking with the carbs I have still a lean mixture between 2500 and 4000 when cruising. But this was no excuse. Today a kind of Track day at the Nürburgring. For 2 hours only Cars, minimum 30 years old on the track. No cruising below 4000 The car was great. Brake excellent. After some laps a bit sailing over the front. Nankang NS 2r. First time I drove these tyres. No experience so far with the tyre pressure. It was fun fun fun and fun. 3
Nick Jones Posted May 15, 2022 Posted May 15, 2022 Excellent! After "some" laps....... Car is home again..... how long since you last drove it there?
Martin Posted May 16, 2022 Author Posted May 16, 2022 With that car, last race October 1988. Then Martin and car retired.
Escadrille Ecosse Posted May 16, 2022 Posted May 16, 2022 1 hour ago, Martin said: With that car, last race October 1988. Then Martin and car retired. Good to have you both back
Martin Posted May 26, 2022 Author Posted May 26, 2022 That lean area between 2000 and 4000 was upsetting me. Thus I thought some bigger idle jet would be good (27 Euro for 4 ouch). But then I thought and googled a bit. The idle jet does not only cover the idle mixture, but in addition is responsible for the mixture between idle and part throttle operation. There are so called progression holes that enrichen the mixture after slightly touching the throttle. What I had not recognized so far was that there are different sizes of progression holes. Two pictures. Weber DCOE in the GT6, which is running perfectly from idle to full throttle. And from the Polo, with a lean spot / area.
Martin Posted May 26, 2022 Author Posted May 26, 2022 (edited) The first hole towards the engine is the same in both carbs, appr. 1mm. In the GT6 then both holes are 1.6mm In the Polo both are 1mm. Thus I removed the carbs, drilled the two holes in the Polo with 1.5mm. Other car. Lambda is now in the tick over / part throttle area between 0,85 and 0,9. Car runs smoothly (taking into account the 316 degrees cam). Now only too rich at full throttle, but there I have to work on a slightly smaller main jet. The bigger idle jets not needed. Fun to drive Edited May 26, 2022 by Martin
Escadrille Ecosse Posted May 26, 2022 Posted May 26, 2022 Brave man. However glad it has sorted the issue
Nick Jones Posted May 26, 2022 Posted May 26, 2022 Smart ….. Dave (the original Mr Sideways) used to get excited about progression holes (more of a thing on Dellortos than Weber’s IIRC). There’s at least one (old!) thread on here on the subject.
Nick Jones Posted September 23, 2024 Posted September 23, 2024 Great to see it getting used Do you use it on the road too?
Martin Posted September 24, 2024 Author Posted September 24, 2024 At present not used often. Unfortunately all of my classics not so much in use. Sometimes I think I should sell one or two cars. But which ones? I like them all. 2
Nick Jones Posted September 24, 2024 Posted September 24, 2024 I know what you mean. Even with just two classics it is a bit of a challenge to keep them exercised and in top condition. Especially when the “modern” fleet is old and demanding…. What is your full list these days? GT6 Mk 2 Vitesse estate Polo Mini (x2?) what have I missed?
BiTurbo228 Posted September 24, 2024 Posted September 24, 2024 1 hour ago, Nick Jones said: I know what you mean. Even with just two classics it is a bit of a challenge to keep them exercised and in top condition. Especially when the “modern” fleet is old and demanding…. My solution to this has been to gradually do away with the 'modern' fleet, replacing them with classics. I'm not sure I'm a ringing endorsement for this as an approach though, seeing as only one is on the road at the moment 9 hours ago, Martin said: At present not used often. Unfortunately all of my classics not so much in use. Sometimes I think I should sell one or two cars. But which ones? I like them all. I know how you feel! A house move has prompted a rationalisation of my hoard of projects, which is no bad thing and is way overdue, but choosing which ones get the chop is a tricky decision...
Martin Posted September 24, 2024 Author Posted September 24, 2024 the list of the fleet, youngest first, my cars : 2004 Volvo 70 D5 2003 Hyundai Getz 1.1 1991 E30 325 convertible 1988 Mini 1.0 City e 1977 VW Polo 1975 Spitfire 1500 1970 GT 6 MK2 1969 Herald Estate converted to Vitesse MK2 drivetrain Son has 2008 Fiesta 1.4 16v 1992 E36 318 , modified for track days, 328 conversion planned 1975 Innocenti Mini Cooper Wife has 1998 Suzuki Vitara 1
Nick Jones Posted September 24, 2024 Posted September 24, 2024 Hah… I knew I had forgotten some! That’s quite a list. E30 is basically just a slightly improved Vitesse…. 3 hours ago, BiTurbo228 said: My solution to this has been to gradually do away with the 'modern' fleet, My “modern” is 28 years old…. Does that count? 1
