mark spit Posted January 16, 2008 Posted January 16, 2008 Hi, Got a 71 Spit MkIV with an ex herald 1300 engine built by Kingston Sportscars. Lowered adjustable suspension. Currently in the process of fitting Megajolt ignition. Got the pulley off, got all the bits bar plug leads and crank sensor bracket, but found a nice bit of right angle 5mm alloy at work that should do the job. Replacement diff to go in shortly. Going to Classic Le Mans and doing the RBRR '08 in this car ;D Mark
