Greetings.  I live in Fort Myers, Florida about a 3 hour drive from Disney World.   This seems like an active forum.  I have owned my current TR6 (1973) for about 22 years and have maintained and upgarded it along the way.  I look froward to conversing with you all.  Cheers!
Here's the upgrade list and always growing:
Triple Weber 40 DCOE-18 Carbs with ITG air filters
Wide-ban air/fuel monitor and sensor
electric fuel pump
GP3 Camshaft
Roller rocker arms, 1.55:1 ratio
Tubular lightweight pushrods
Adjustable cam degree sprocket
Lightened stock steel flywheel
External oil feed line to head
2 quart Accusump oil accumulator
oil cooler with spin-on oil filter
Early crankshaft (long-tail crankshaft)
Cylinder head shaved for 10.5:1 compression
Ported cylinder head
6 into 1 exhaust header with 2-1/2” single pipe exhaust
Flowmaster Deltaflow Series 40 muffler
PCV and Oil separator
Pertronics Ignitor electronic ignition
Pertronics FlameThrower coil (40,000 V)
Pertronics SecondStrike Ignition box w/ rev limiter
Re-curved stock distributor
Magnecor KV85 (8.5mm) Competition ignition wires
ATI Harmonic Damper
GM 55 amp alternator (NAPA # NNE 1N-4011A from 1978 Pontiac Grand Prix 305 V8, but with 12:00 index).  Use 46-5/8” x 13/32” BELT (NAPA # XL 7460)
5” diameter Moroso alternator under drive pulley
R200 viscous LSD Rear differential from a 280 ZX Turbo (by GoodParts)
7/8” front / 3/4” rear sway bars
Stiff stiff springs
7/8” rear brake cylinders from a Morgan
Carbon-Kevlar brake pads & shoes
Steel braded brake lines
Aluminum Alfin rear brake drums
Carrera adjustable front shocks
Stock rear lever shocks with modified valving and 90 wt gear oil
Early model TR6 high back headrest seats
4-point roll bar
3” Latch & Link lap belts
Battery relocated to trunk
Odyssey PC680 battery (13 lbs.)
Adjustable rear trailing arm brackets
Jaguar front upper ball joints to increase caster
Autocross alignment
Solid aluminum steering rack mounts
16” electric radiator fan w/ thermoelectric switch tapped into heater hose
Custom aluminum radiator shroud with duct toward carb inlets
15”x7” Panasport “Race Only” wheels (street)  15”x10” UltraLight wheels (race)
Over 20 years it doesn't seem such an investment.  Anytime something broke, I upgraded it - much like any project car I guess.  It was my daily driver for 18 or so years, then I had two kids.  Now it's a weekend car.  It handles very well.  Just a touch of oversteer at high speed corner exit.  It's set up for mid to high speed autocross courses.  It's nice to beat those Miatas.
Welcome aboard Tom,
You've found without doubt the best Triumph performance resource on the web.  You'll have to adapt to our cousins across the pond, a bit, cuz they tend to spell funny but other than that they're aces.  Since you're about equidistant between them and us western folk you'll probably adapt quicker.
The car looks good!  It's been years since I autoXed.  SP allows slicks?  What's the class just above stock?  I thought that was street prepared?  Anyway, as I said I haven't AutoXed since about 1990 so I don't know what's current.
OK, I just went and looked at all of my placgues and apparently the GT6 was winning in G stock and E stock in the day.  So I guess I wouldn't know what SP allowed ;D ;D.  I do recall I was careful with the mods because the next class was a slippery slope.
Thanks for the warm welcome.  Yall seem like nice folks.
Regarding autocross, here most run SCCA rules and classifications.  There's Stock, Street Prepared, Prepared and then Modified.  I run with Hoosier A6 tires.  They are technically street legal (DOT approved) but are really slicks with two small grooves around the tread.
You'll have to adapt to our cousins across the pond, a bit, cuz they tend to spell funny.
What do you mean smell funny Steve!!!!!!!!!!!!!!!
Wlecoem Mot - also a good bit of banter and a laugh - nice too see a US spec car with Uk bumpers - looks right
