  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
All,
In case anyone had similar doubts to me, I got the following email direct from Mintex.
"M1144 is primarily a fast road product, in order to be legal for the road on vehicles produced after September 1999 it requires a Regulation 90 certificate, for vehicles produced before this time no certificate is required, hence these pads are fine for road use on your Spitfire."
So there's no problem fitting these pads to our cars legally - which is nice.
Doug
Martin unless I am very much mistaken we are talking about brake pads. You change these by removing the locking pins and sliding in the new pads in place of the old. Usually you need to spread the calipers apart as you will be putting meaty (i.e. thicker new) pads in place of worn thinner pads.
Neil
Mintex M1144 pads fitted this morning.
After 50 miles running in they are quite simply fantastic compared with the £7 jobs I got from one of the usual suppliers.
There is virtually no comparison.
Cheap crap pads are simply a thing of the past for me now.
  • 5 months later...
http://www.compbrake.co.uk/Triumph%20Upright.htm
One I stumbled on, never seen it before!
off subject but blokes a wanker - I looked long and hard over 15 years to find a billet caliper that fits striaght to a GT6 upright using a 2.8 disc - bought a set of calipers and with 9mm machined off the spacer - could not get a better fit on the GT6 upright with a 2.8 disc - but no option for dust shields on the pistons.
Tried to get an additional 4 shorter bolts off them as they are not an off the shelf length (thier stock caliper has 2 short and 2 long bolts) - must of caught him on a bad day - tosser - this could be my first rant!!!!! Anyway after my phone call I put the calipers striaght on fleebay and sold them - would never have any of thier products again
Also be aware thier GT6/Vitesse alloy hubs do not fit correctly due the outer bearing not sitting in the same location as the OEM hub - market is Chaterhams and they think that it fits striaght onto the Triumph - you've been warned!!!!!
How did you do that ???? thats not what I wrote!!!!!!!!!!!!! ahhh a censor!!!! so thats why
i have to say that my high spec princess lug calipers with mintex 1144 pads and 2.8 capri discs on gt6 upright feel really good at the moment, obviously not tested on track yet but the peddle is really good( much better with good pads) and responsive
Spoke to the bloke Compbrake today, chatted for a while.
Won't be so helpful once he's got your money and you've a technical problem with supplied parts that don't fit!!!!!
  • 4 months later...
i exchanged a few emails with brent and stephen at compbrake concerning their gt6 kit, but now their website doesn't seem to be working....
doesn't give me much confidance, considering mark's(gt5r) comments....
What they don't understand is that there are two different uprights/stub axles and hubs for Spitfire and GT6 - I even sent them a GT6 vertical link and hub to compare it against - got no joy as he was right all the time
is this a fairly easy swap?
and does it fit inside 13" wheels?
The problem with this route using Princess callipers on a GT6 upright is that you have to use and machine a 1600 caliper carrier at its weakest point to fit the vented disc - I really don't like this mod and having used a set of Princess callipers on the track which I used once in practice and took them straight off as they were worse than the standard callipers. If its a Spitfire upright the Princess caliper will bolt striaght on - if you are using original Princess calipers they will need spacing as the Princess disc is not vented - you can actually machine the stock caliper and fit a vented disc without a spacer as this is what I did on my race car
For GT6 you will be better off with a spaced standard set of callipers and a decent set of pads than the more common method of using the 1600 caliper carrier which I believe is to weak once machined (buts that just my opinion) and the Princess HI Specs
You could investigate Subaru 4 pots - as I think you might find the Scooby's have the same mounting centres as the standard GT6 upright - It was something I was going to investigate but due to a complete suspension change at the front I never got around to it
