zetecspit Posted November 23 Posted November 23 I have stumbled across "cyclical timers" which appear to have variable on/off timers. Seems they may be suitable for creating intermittent wiper setting? (I am also thinking as a controller for an electric oil pump to feed my garage heater!) Anybody understand this stuff and can tell me if it should work? One example linked below, cheap and cheerful https://www.aliexpress.com/item/4001282910152.html?spm=a2g0o.productlist.main.19.48c727ecusgDuU&algo_pvid=6d7fa895-6a34-499f-8eb7-8027806fd4b5&algo_exp_id=6d7fa895-6a34-499f-8eb7-8027806fd4b5-18&pdp_ext_f={"order"%3A"19"%2C"eval"%3A"1"%2C"fromPage"%3A"search"}&pdp_npi=6%40dis!GBP!8.41!4.12!!!10.68!5.23!%4021039a5b17638908409304960e9106!10000015594962182!sea!UK!6126978517!X!1!0!n_tag%3A-29919%3Bd%3A35ed5ded%3Bm03_new_user%3A-29895&curPageLogUid=Vz8TDCqVKRcP&utparam-url=scene%3Asearch|query_from%3A|x_object_id%3A4001282910152|_p_origin_prod%3A
RogerH Posted November 23 Posted November 23 (edited) Hi Clive the only problem I can readily see is that it controls from 0 to 100 minutes For your wipers you are looking to hold the earth down for apprx 1second. So you may not have the adjustment/resolution to acheive this. However they are so cheap get one and find out. Roger Edited November 23 by RogerH
RedRooster Posted November 23 Posted November 23 Changing the potentiomètre is maybe all you need to do to change the span?
zetecspit Posted November 23 Author Posted November 23 1 hour ago, RogerH said: Hi Clive the only problem I can readily see is that it controls from 0 to 100 minutes For your wipers you are looking to hold the earth down for apprx 1second. So you may not have the adjustment/resolution to acheive this. However they are so cheap get one and find out. Roger In the bumpf (which may or may not be accurate!) is says there s a jumper to change from 0-100 seconds, or 0-15 mins. (not encouraging as the headline says 100 minutes, but we live in hope) I will give it a try, no big loss if it turns out to be junk like 50% of the stuff sold on those sites.
RogerH Posted November 23 Posted November 23 If the circuit used the ubiquitous 555 timer then changing the time span would be simple But the advert showed a seriously multi legged device. Roger
