rogerguzzi Posted May 6, 2025 Posted May 6, 2025 Hello All The motor on my big lathe trips the earth leakage relay out I have tried removing the earth but no difference! It is a capacitor start type and flameproof (ex petrol pump) Do you think it could be the capacitor that is causing the fault as I have 2 spare motors I could take one from and I think change it in position(easier than changing the whole motor! I looked at one in a spare but can not see any size reference! Roger
Nick Jones Posted May 6, 2025 Posted May 6, 2025 Is this an instant trip as soon as power is applied? May be worth trying a capacitor swap, but as you say it does it with the earth disconnected I wonder about the leakage relay itself? Do you have a meter with megaohms reading? Ideally you want a high voltage tester for the winding insulation but it might tell you something.
JohnD Posted May 7, 2025 Posted May 7, 2025 In my ignorance, I thought that the capacitor on an electric motor was to deal with the large current they draw on starting. My compressor has needed a new one twice, in about twenty years. It would chug-chug-durrrrrr and die on starting. I know the sound now! Is that what yours does, Roger? Me, I'd take an earth current cut-out (RCD?) tripping very seriously - they are there To save your life! John
DeTRacted Posted May 7, 2025 Posted May 7, 2025 The capacitor is probably a starting capacitor for the motor John. it is used to produce an extra pseudo-phase supply 90 degrees shifted from the real single phase supply and driving a separate auxiliary winding. Having a second phase drive gives the motor much higher starting torque to get it up to synchronous speed quickly. The capacitor is disconnected by a centrifugal switch once the motor is running at speed. Unless it has an earthed metal case, failure of the capacitor should not cause an RCD to trip as it only results in excess phase current rather than an earth leakage but it could trip an RCBO or an MCB as they also trip on excess supply current. An RCD should only trip if some current is being diverted to earth through a failure in insulation, instead of returning through the neutral wire. Essentially it looks for a difference between the supply and return current. As Nick says, if the earth is disconnected a diversion of current cannot happen so the RCD should not trip. (Of course disconnecting an earth is NOT to be recommended .........)
zetecspit Posted May 7, 2025 Posted May 7, 2025 As others have said, the RCD compares current on L+N. More than 30mA and it trips (often less than 30mA when tested) So some current is escaping somewhere, if not through the earth wire then though the machine to earth, or you. But that 30mA is the assumed safe limit for humans. You really need a proper tester,my gripe with testing it is not easy to do with an appliance running. I do some PAT testing, that uses 500V , joins L+N and checks resistance to earth. Done to not damage whatever is being tested.
JohnD Posted May 7, 2025 Posted May 7, 2025 (edited) There you go! The Common Room of the Sideways University has experts (and I don't mean drips!) in any subject! Thanks, to m'tutors! John Edited May 7, 2025 by JohnD
Sigma hurricane Posted May 7, 2025 Posted May 7, 2025 3 hours ago, JohnD said: In my ignorance, I thought that the capacitor on an electric motor was to deal with the large current they draw on starting. My compressor has needed a new one twice, in about twenty years. It would chug-chug-durrrrrr and die on starting. I know the sound now! Is that what yours does, Roger? Me, I'd take an earth current cut-out (RCD?) tripping very seriously - they are there To save your life! John To be fair John lots of motors especially compressors have soft start for this exact reason however they manipulate the voltage via solid state semiconductors. The high voltage and current to get motors going is normally what kills the windings and eventually results in the motor “grounding” out. Either that or bearing failure tends to be what kills motors.
rogerguzzi Posted May 7, 2025 Author Posted May 7, 2025 Hello All Thank's for the advice it looks like I am in for a motor change!!!! It trips out the instant the starter is pressed I may try disconnecting the earth elsewhere just for test but with gloves on and not touching any metal that could be live(no desire to die ) I suppose 44 years is not bad and I have 2 more I can use so no cost in £ss just muscle power(or lack of it?) Still we have been out on a good run today Breakfast a Church Stoke (wales) then Llanfair Caereinion railway for Ice cream then back to Craven Arms Discovery Centre for Tiffin!! It's a Hard life but we do not mind doing our share!! Plus only 172 miles covered and Spitty still doing 45mpg Roger
mpbarrett Posted May 8, 2025 Posted May 8, 2025 13 hours ago, zetecspit said: As others have said, the RCD compares current on L+N. More than 30mA and it trips (often less than 30mA when tested) If I remember its a combination of current and time, I think the standard is 30mA for 30mS, higher leakage will trip it faster. All based on what the human body can survive with out being killed! Is it a RCD device or combined RCD and overload, RCBO? If it is it could be tripping due to high current or leakage... BTW RCD;s do fail so its worth using the test button occasionally. Had a MK RCBO in our DB fail to trip when the test button was pressed. mike
zetecspit Posted May 8, 2025 Posted May 8, 2025 Yes, thoroughly encourage everybody to test their RCDs AT LEAST twice a year. They can get sticky. I have tested RCDs to be as low as 24mA, not that it really matters. Most around 27/28mA Trip times always well under 30mS, some in the teens, which is reassuring. 1
rogerguzzi Posted May 8, 2025 Author Posted May 8, 2025 Hello All No luck I fitted a different RCD (Same) I fitted a 3 pin plug to motor wire to rule out starter and wiring (Same) So I have removed the bloody heavy Barsteward while lying on my side (I am sure it was easier 40 years ago?) Now just have to remove the pulley and refit the bloody thing with head under the swarf tray lying on my side(DEEP JOY!!!) Roger ps I could cut the wall out of the garage and work easy? (Perhaps not!)
ahebron Posted May 8, 2025 Posted May 8, 2025 RCD protect people MCB protect equipment. I have had new RCDs fail, fail,fail, new one arrives and old rcd pass, pass, pass. Very infuriating but still replace as old one had a fault.
zetecspit Posted May 9, 2025 Posted May 9, 2025 7 hours ago, ahebron said: MCB protect equipment. Being picky, the MCB is there to protect the wiring from being overloaded.
spitfire6 Posted May 10, 2025 Posted May 10, 2025 Disconnect the motor wires/connection and see if the RCD/RCBO trips.
egret Posted May 10, 2025 Posted May 10, 2025 On 5/7/2025 at 7:34 PM, rogerguzzi said: Forgive the tangent here, but nowadays it's rare to see such a lovely colourful carpark!
rogerguzzi Posted May 10, 2025 Author Posted May 10, 2025 6 hours ago, egret said: Forgive the tangent here, but nowadays it's rare to see such a lovely colourful carpark! A few more for you Roger 1
rogerguzzi Posted May 11, 2025 Author Posted May 11, 2025 11 hours ago, RogerH said: I like roads with grass down the middle Roger Hello Roger That's a road coming down off the Long Mynd and tests your brakes for sure We had just been to the Glider station for Breakfast recommended and some good views from up there! Roger ps about 1 in3 to 1 in 5 and narrow!
rogerguzzi Posted May 24, 2025 Author Posted May 24, 2025 Hello All Well the Saga continues!!! I tried a different capacitor no change so I dug another motor out and swopped the pulley over and the drilled rear cover(Flame proof and rated at 1/2 hour!) Crawled around the back of the lathe a fought the bloody heavy thing into position and fitted the vee belt switched it on and all seemed ok for about 5 mins the it trip the starter out on thermal overload tried increasing it no luck! So fought the Barsteward off AGAIN and sorted out another motor and did the same mods spent 2 hours trying to fit the Barsteward only to realize the the bolt holes are different centres !!!!! So sort another motor out and bugger it is the same but the better news is they are rated at 1hour! So now I have to try and unbolt the rear mounting on the back of the lathe and move it 1" closer I think if I did not have Bad Luck I would have no luck at all!!! Roger ps I hardly ever use the big lathe now I have the Chinese one but it is useful for flywheel type jobs etc
Nick Jones Posted May 24, 2025 Posted May 24, 2025 Something tight in the lathe transmission/bearings increasing motor load? Seems unexpected to have 2+ motors faulty? What size motor? 4 pole?
rogerguzzi Posted May 24, 2025 Author Posted May 24, 2025 Hello Nick The first one has lasted about 44 years the other one maybe just pulling to much power all these motors are 45+years old and salvage out of damaged petrol pumps and some done service as water pumps for our off grid living! Perhaps I should have spent about £100 on a new one but I am like you!! (In my case buys more wine) Careful (Tight!) Still off to Spain in 3weeks in Spitty and going to Lugo Again as we have a soft spot for it as Spitty had the drive shaft fail that was repaired there in the underground car park! Plus it is a nice walled town with good Tapas and cheap as its not on the Benidorm type circuit!! Roger
rogerguzzi Posted May 25, 2025 Author Posted May 25, 2025 Hello Nick I assume its 4pole as it is 1500rpm but they a.re only 1/2hp and will not pull the top speed on the lathe until it is nice and warm But I hardly ever use top speed as its usually doing a big job (Flywheel etc) I can even swing a 19" motorcycle wheel with the bed gap removed to skim a brake drum! I have managed to move the motor mounts 1" and fitted the motor and run it and it sounded quiet ish and did not trip out I will run it for longer later before fitting the guards etc So now hoping this one is OK! It must be heavy as the casting under the headstock is over 1" thick!! and there is strengthening ribs inside!! If we ever sell the cottage it will be included in the sale Roger
Nick Jones Posted May 25, 2025 Posted May 25, 2025 Ah.. 1/2 hp (0.37 KW) is pretty small. Too small perhaps. Think my Myford is 0.75….. Do you know what frame size?
rogerguzzi Posted May 25, 2025 Author Posted May 25, 2025 Hello Nick Yes it is a bit small but as I said I do not use the top speed much (750rpm) the next one is 500rpm which is ok for most jobs as they tend to be large (flywheels etc) I ran it for about 30 to 40 mins with the clutch engaged so it was turning all the gears in the head(its an all geared head) The motor only got slightly warm but I have swopped the end cover for the one I drilled holes in and mounted a small fan (ex built in oven)behind it and wired it so when the power is on to the lathe the fan runs even if the motor is not so should help cool it a bit? If this one lasts 40+ years I would be 120 years old!!! I even reduced the thermal overload settings in the starter unit down to 4.5 amps as the motor plate is stamped and it is a top quality one Allen West as my Dad worked for them back then. Its this type of unit but not in a case as it sits inside the base they are the bees knees of starters and oil damped and I think silver contacts or they were back then not like the cheap MEM stuff! Starter SCI Allenwest SC1 - Axxa - Motor Control & Automation Roger
