Not really a hobby, per sae, more a necessary chore.
Firewood. I burn a lot.
I already have maybe 6 tonnes already cut and split, this is all rhodedendrum cleared from the garden.
However, I like to have pine in as well (open fires so advantage using hardwood for me, most of the heat goes up the chimney!) so a quick chat with the local forestry office procured an additional 3 tonnes of 3m lengths of larch. "There's maybe 5 tonnes there" the guy says, "take what you want".
So, trailer hooked up and checked.IMG_20201006_113124.thumb.jpg.dad42918aa2da7d350ad5c5ed619633b.jpg
First load collected, however now for the tricky but. I have to reverse down here.........
Not much room for error either:
And an interesting bend at the bottom:
But the first load is stacked!IMG_20201006_113235.thumb.jpg.5f929bf5dbbe23f4bebe5002a6304318.jpg
There's maybe a tonne and half in there, maybe a touch more (I halved it all before stacking, a lot of that is at least two men handling, some bits 3 man!). Lucky I have two willing helpers :laugh:
And now back again to get the second load. Unfortunately we have taken the "light" stuff, so heavy lifting will have to begin.
Second load back. Definitely much heavier load this time, but better loaded (first load I put at the front which gave me too much hitch weight, even though I was within the trailer capability).
Actually had to go into first gear to get up my drive (which is steep to be fair).
Just got to unload, cut and stack it all now!
Damn right it's a lot of wood, used quarter of a tank today, it's a 50 mile round trip to Aberfoyle, and the fuel usage was mostly on the full runs! Equates to 50 miles costing £30 in diesel.
My 2 willing helpers also thought it was a lot of wood :whistling:
IMG_20201006_161822.thumb.jpg.c16a7912f317597f21b3da8a17d5f5e0.jpgIMG_20201006_161826.thumb.jpg.3a175ebe99689133617fbd8700cc01b3.jpg
This load required splitting on the trailer where possible:
The finished stack:
IMG_20201006_163244.thumb.jpg.9f5cf66b1490cdb9041957340207b104.jpgIMG_20201006_163252.thumb.jpg.a9f6239e2dea65c24fc1eb8c3d7d7761.jpg
And a few rounds cut down, I shall split these down shortly (judged to be too big for SWMBO to move by herself, so we decided to cut and split them straight away).
Truck never skipped a beat all day, just me that is a bit knackered now lol.
Final splitting done. Glad I got this axe now, the old one is smaller and would have required substantial effort on this, still a bit wet.
And just for the hell of it, a video of the final two logs. Excuse the miss on the second last hit lol.
Man of your calibre shouldn't be chopping wood, when such excellent machines as these have been designed
I was eagerly anticipating severed limbs (or at least digits) and copious blood. Instead, all these machines were operated by phenomenally lucky people.
5 hours ago, PeterC said:
Burning pine  will soon clog a chimney with layers of ash embedded in condensed resin.
Peter
Your right there, it should stand for at least a year and even then it isn't the best thing to burning,
RR
             I think I take risks but am a complete Amateur compared to these people.
I really like the backless slippers in the second one!
Peter
Aye, I also have the chimney swept annually by an external company, along with regular sweepings by myself (the external company satisfies insurance requirements).
I agree that hardwood is better, however this also depends on how you burn it. I have open fires, where roughly 2/3's of the heat goes up the chimney. In my area, hardwood is roughly £80 per tonne (builders bag full). I have just collected over 4 tonnes of larch for £75. The extra heat from hardwood does NOT justify the cost, and further hardwood is simply not sustainable in Scotland currently.
I tried a powder that was claimed to be used in coal-fired power stations to reduce flu encrustation. Looked like iron filings. No idea if it worked but as the flames looked unchanged I lost interest, along with its name.
Peter
Peter
Never thought to see if you got those for chimneys tbh, I do use similar onboard on Exhaust Gas Economisers and Auxiliary Boilers (Both of which have a bad habit of choking up over time). That stuff works though, doesn't negate having to water wash the tubes every 6 months, however it does speed the process up dramatically as washing takes far less time to do. That's a nasty green powder though, and doesn't need to be burned (though the Boiler takes a slightly different form that does react with flame), does some funky stuff to your skin if you are not careful!
