Mazda gearboxes.......
Nick, nowhere near what you achieved to maintain the original position.
This is what I managed today after picking up a Mk1 box and following Manana's example. Need to shorten the tube and selector shaft but, this slides freely. Need to make a rear support bracket but have shortened it 148mm (could make it 6" easily enough) which I think will be fine for me and it also means no major surgery to the handbrake position.
Also ground away the side were the PFF mounts, think I will also mount it the using original holes again, as Manana. So much easier when you follow some one else's hard work - thanks both!
  • Replies 115
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Have now finished the adapter ring. Quite happy with the way it turned out. There was a certain amount of fettling required for the final fit but once that was done it dropped into place nicely - and,
Hello Nick                  How about a stretched limo look? The Satnav had locked onto this? but the view was worth it and me and the Memsahib had a nice picnic and a nice ice-cream on the
Unmolested box in the background. Easy conversion moves the remote forward the distance between the bolt holes - 104mm. (yellow) I think you could just about get 175mm and retain the original sele
Posted Images
Nice work there Fuelish.  When we did mine we left the shifter rod in there and slid the Change Control Case forward until it hit the case, then it was really easy to see what needed to be trimmed to get a snug fit against the casing.  Of course the biggest thing to look for is free movement of the rod.
Nick, I know that you are past the notion of relocating the Hand Brake, but in case you're interested in the details of how I did it, I've added that section to my site.
https://stevew10.wixsite.com/spit16/copy-of-fuel
Looking forward to seeing yours in action.
I did follow your example and could have ground the top of the casing a little more and cut 2mm more off the front of the 'shifter' housing but for me a relatively disproportionate amount of work to gain 1/4". One thing I have been fortunate with is the seal on the rod tube; I managed to ease this off gently one end without damage. Now the tube is cut down to bridge the gap I can reuse the sleeve seal with some blue Hylomar or vulcanising glue.
Have read you blog on moving the handbrake with interest. I have something planned here as trying to go for rear discs but want proof of concept before opening my mouth :thumbsup:
Brief update with all bits ready for final assembly, shortened selector moves freely and shaft tube seal is glued back on with rubber solution. Not gone overboard with a super strong rear support but it is rigid, using one bolt hole and an original centre dowel to locate. Bracket needs a tidy and like to use Zinga to protect.
Look forward to NJ's solution for an 'as original' position.
Nice, you're actually further forward than me.  Shaving down the case got you a bit more. TU.
Nick, I'm wondering if you are going to put a dog-leg in your shifter like the Spit has?  It may be very close to the panel, no?
Nice, quick work Fuelish. Looks good.
Yep. Lever needs a kink in it or you punch the dash.
Prototype. Both sides of the kink have been shortened since this pic was taken. It’s actually very similar to the stock GT6 one.
I wrestled the box back out and did some clutch related measurements in the bell housing. The flywheel and backplate went onto the spare engine and got measured too, as did the chosen slave assembly which is from a Vauxhall Omega as recommended by Marco on the TRR forum.
He’s done a lot of work on concentric slave cylinders for TRs and more recently his own MX5 gearbox conversion. Detailed thread on it here with lots of useful info
https://www.tr-register.co.uk/forums/index.php?/topic/68790-hydraulic-clutch-release-bearing-for-tr4a-tr6/&tab=comments#comment-616926
This showed that things were tight and would only be possible if the clutch set height (rest position of the diaphragm fingers relative to the flywheel face) was in a fairly narrow band. I bought a new 215mm Mazda clutch plate (8.4mm thick uncompressed)and measured the finger position compared again. I also measured with no friction plate at all and with the most worn one I could find (7.6 mm thick uncompressed) all of which gave me some understanding of how it works.
The other question was how much stroke is needed to fully release. Having failed to find anything published, I plonked a flywheel/clutch assembly on the mill table and used that to compress it until I could easily move the friction plate.
6mm.
With those numbers I could draw myself a picture to see if it could work.
Yep. Still tight, but possible. Time to bother some metal.
The object is to build something that accepts a bog-standard slave assembly as a direct bolt-on.
It needs to be accurately concentric with the gearbox shaft.
As space was extremely tight, the gearbox bearing cover/guide tube needed shortening - quite a lot. In fact to the extent where I did wonder about making a new one from scratch before deciding that it was too fiddly and the scope for cock-up on the concentricity front too great.
Matters were complicated by the thing being too big to swing on my rather small lathe. So out with the mill turntable again. That meant making a little spigot to centralise the casting on it, which was easy enough and worked very well.
Then I had to make an adapter plate. This couldn’t be more than 5mm thick overall and needed a 1.3mm tall spigot in the centre to locate the slave, so I used steel.  A piece of 100mm wide x 5mm flat(ish) strip.
First step was to drill and bore the central hole on the mill and then make it roughly round with the grinder before popping it one the lathe. Was a bit fiddly and time consuming but came out ok.
It’s centralised by being a snug fit on the slightly slimmed-down and shortened stump of the guide tube. It sits on the remnants of various casting features and will be further supported by 4 spacers picking up on mounting bolts as I’m not certain how able the now fairly thin casting is to take the clutch thrust load. Probably overkill, but easy enough to do now.
Thanks. I’m quite pleased with it so far. Pity it will be well hidden.
So long as it works and keeps working, I’ll be happy.
My main worry is that because the CSC has a fairly strong spring in it to keep the bearing in constant contact with the clutch fingers, even a small amount of runout will quickly cause problems (destruction of the CSC most likely).  I think this last lot of work is pretty much bob-on, but the same need also applies to the bell housing adapter etc and I’m less confident about that.
Possibly the spring in the CSC could be removed but not quite sure how that would go....
The other question that arises is how well the fairly flat faced release bearing (designed for use with curved spring clutches) will play with a flat spring clutch.......
Might have done better with the Saab CSC but the decent ones are fearsome expensive..... and they have a much shorter working range without their basic length being any less.
Sunday was cold. Garage temperature 2C, but at least it was out of the wind.
I did venture out long enough to make the 4 spacers from a length of aluminium bar stock.
They sit like so
I made them very slightly long so the plate sits about 5 thou above the centre pad. This to ensure load is taken by the spacers first. Seemed like a good idea at the time.
I milled the bolt pads on the original casting first so they are all identical thickness and spent some time making sure all the spacers are the same length. I’m serious about getting everything concentric and perpendicular.
Of course this means four of the OE bolts are now too short. Some rummaging among bolt stocks found three that are absolutely perfect in every way :smile:.... I need four though.....:blink: There were four, I remember where they came from, what I can’t remember is whether I used the other already of if it’s “at large”. :confused:There is a lot of “stuff” in my garage......
I’ve been adding pipes
The selector thingy got heat-treated (maybe), cross-drilled/tapped and the neutral switch hole plugged with a chopped down M14 bolt.
Have done a test re-assembly to check I’d got the cross-drilling (yep, thankfully, the age of miracles is not quite past) it all came apart again so I could give the rear case a final swill out before fitting the selector shaft oil seal. It’s a strange size hole @20.5mm,  so a 20mm seal falls in (and out) but 21mm is flipping tight. Got it eventually after making a tool.
Mostly assembled. Made some covers. Not intended to be oil tight but should keep the wort of the grime out.
Even got a little plug for the end. It’s got a 1.5mm hole at the top to allow it to breathe as the shaft moves.
Getting quite close now.
Time to try the 'box on an engine with all the clutch parts in place.
Didn't have a centering tool to suit the Mazda sizes so I made one
Who needs splines......
Performing its duty
Apparently it worked.
Then poke the phone inside to see how things were sitting.
The bearing is definitely in contact (which it should be), but can't see how compressed it is.  The engine still turned over fine - no funny noises from the bell.
Will do some more measuring tomorrow to double check.
