Pfen
Switch bezels
I have a tool to tighten and undo the switch chrome bezels on the dashboard.
The car is stripped for repainting, dashboard included, but how do I retighten the bezels without scratching the paintwork. There wasn't a washer behind the bezel that I know of.
I thought there were thin fibre or rubber washers under them originally which crumble to dust with age?  Certainly none left on anything I own but they've all been apart before and the dashes are too, err, patinated.... to care.
Pfen,
You have a tool, or want one?  I made one from a piece of alloy that was the same thickness as the slots in the rim of the bezel.     Cut a notch in the side of the plate to clear the switch handle, formed a flange on the free side, to provide stiffness.
Hi Pete,
firstly ensure that the pins are not too long on the tool.
Next - make sure that flat side of the bezel is flat - rub down on W&D.
You could now take a chance with the above or bond/glue a layer of thin plastic to the flat side.
Roge
9 hours ago, JohnD said:
Pfen,
John Thank you for your tip, but Roger very Kindly made me one, 2 actually, so I am OK thank you.
8 hours ago, RogerH said:
Hi Pete,
Roge
that sounds a good idea will source some thin plastic.
best Pete
