zetecspit Posted January 11, 2019 Share Posted January 11, 2019 Advertising on behalf of a tech-phobic friend. Overdrive box (with overdrive) from a later dolly 1850, so single rail j type. Been completely stripped, cleaned, checked, anything damaged replaced. Rebuild with new seals/gaskets. £395 J type overdrive, 25% ratio. Built into single rail casing, though this will happily fit a three rail box (just some extra lugs) supplied without solenoid etc. But same treatment as the gearbox above. £150 Another 2 J types are in the pipeline, both with solenoids etc and will be £175 Located in Sussex, but can arrange to take them to the Stoneleigh spares day. Link to comment Share on other sites More sharing options...
triumphlux Posted January 12, 2019 Share Posted January 12, 2019 Hi, sended you a pm JC Link to comment Share on other sites More sharing options...
zetecspit Posted January 14, 2019 Author Share Posted January 14, 2019 The gearbox has been sold, along with one overdrive. I have a feeling there is a d type OD available, will check later (Pete has had a busy Christmas doing gearboxes and stuff!) Link to comment Share on other sites More sharing options...
PaulAA Posted January 15, 2019 Share Posted January 15, 2019 Clive I've PM'ed you. Paul Link to comment Share on other sites More sharing options...
