JohnD Posted June 18, 2018 Share Posted June 18, 2018 Two weeks ago was Oulton Park, and an unscheduled exit over grass into a gravel trap. Since then, I've been working to get the parts and fit them to deal with the damage caused, and finished on Sunday PM. Congratulatory drink, and a start and test run postponed until this morning. But on flicking the switches - nothing! Some items ran, but not the fuel pumps, so a start wasn't to be possible. OK, out with the multimeter, this'll be a doddle, especially if I bear in mind my mantra - what did you do, where were you working? The last time you did something to the car? It must have been something I dislodged. But all the fuses intact, no loose connections, just no volts at the appropriate switches. Lying under the dash, neck aching , back being poked into by something I know not what, I traced the wiring, which hasn't been standard for a long time, and for which the only wiring diagram is the thing itself. And it was all intact. Finally, I traced it to the ignition relay, which I installed for reliability, as there are so many electrical extras. It was warm, unsurprising given that the circuits had been on for so long while I tested. And it clicked as I turn the ignition on and off. But I have a spare, pop it into the rack, easy check - and it all works! The relay had failed! How often has that happened? An easy repair, if a bit mysterious. And I must have another spare, as I'm off to Spa for next weekend. Good Old Halfords! They had several Type A relays, but no Type 'B', but went out to the back and returned with the correct one - sorted! John Link to comment Share on other sites More sharing options...
oldtuckunder Posted June 18, 2018 Share Posted June 18, 2018 Glad your back together in time. Don't know if the Gravel at Oulton is like the Kitty Litter at Prescott but even with only a minor excursion at the end of last year, I spent the winter with it coming out of every nook and cranny, the vacuum cleaner was added to work shop necessary tools! I don't think i ever had a relay fail, until I fitted the Revotec Fan 5 years ago, then I had two fail on it in 12 months, Revotec were good and always supplied replacements, and not had one fail since, but now I always carry a spare in the competition tool box, and as with MJ and EDIS now installed and relay dependant probably an even better idea. Alan Link to comment Share on other sites More sharing options...
Nick Jones Posted June 18, 2018 Share Posted June 18, 2018 I pull Bosch relays from scrapers. Never had one not work or fail. Nick Link to comment Share on other sites More sharing options...
JMH Posted June 19, 2018 Share Posted June 19, 2018 @John - how much load is on the relay? Link to comment Share on other sites More sharing options...
