GT6Steve Posted May 24, 2018 Share Posted May 24, 2018 I never did master AutoCad and lost the opportunity shortly after these were done. If there's anything useful enjoy it ;-) camshaft lock plate2.pdf camshaft lock plate.pdf 2GT6 Cam Drive Sprocket- Chain2.pdf TR6coordinates.xls stretch gauge.dwg Spring.dwg Rear engine plate.dwg Rear engine plate Excel.dwg GT6 Cam Drive Sprocket- Chain2.dwg GT6 Cam Drive Sprocket- Chain.dwg distributor pedestal.dwg Diff insert.dwg camshaft lock plate2.dwg camshaft lock plate.dwg Bridgeport Adjustable Worm Shaft.dwg 2GT6 Cam Drive Sprocket- Chain2.dwg Link to comment Share on other sites More sharing options...
JohnD Posted May 25, 2018 Share Posted May 25, 2018 Steve, I've been learning Dassault's Solidworks, which is compatible with the .dwg files you posted. But they download as .edrw files, which can only be run in Drawing Pro, also a Dassault Systemes product but a much lesser one, that doesn't permit the manipulation that SdW can. If you can post them as .dwg or .dxf files, or even as many other formats that SdW can use, then maybe they will have further use. See: http://help.solidworks.com/2016/english/solidworks/sldworks/c_File_Types.htm John Link to comment Share on other sites More sharing options...
GT6Steve Posted May 25, 2018 Author Share Posted May 25, 2018 I have no idea John, They are dwg's in this thread? Converting them to PDF's has been very iffy so perhaps the version is too old? Link to comment Share on other sites More sharing options...
