Nick Jones Posted May 16, 2018 Share Posted May 16, 2018 1 hour ago, RedRooster said: All the Triumph engines i have worked on have had the caps numbers etched on so shouldn't be a problem. Provided they came from that block...... Actually, if the numbers are a set they'll probably be fine. One of my 2.5 engines turned out to have two #3 caps and I don't think either was from the original block. It also had "shims" made from a coke can to allow it to turn. Made some odd noises when warm..... That's the one I fired up on the garage floor and was so impressed with the oil pressure I went to the trouble of putting it in the car......... Cold oil pressure means nothing! Nick Link to comment Share on other sites More sharing options...
oldtuckunder Posted May 16, 2018 Share Posted May 16, 2018 I've seen numbered ones in the wrong slots, and around the wrong way. Just saying if it wasn't a block I knew to be good, I'd check it. Link to comment Share on other sites More sharing options...
RedRooster Posted July 24, 2018 Author Share Posted July 24, 2018 Just a quick update, the fifty quid block had already been freshly bored to +40 so thats saved me a few quid Link to comment Share on other sites More sharing options...
Nick Jones Posted July 24, 2018 Share Posted July 24, 2018 That's good news Nick Link to comment Share on other sites More sharing options...
RedRooster Posted July 24, 2018 Author Share Posted July 24, 2018 Yes indeed the block has paid for itself already! Link to comment Share on other sites More sharing options...
RedRooster Posted August 16, 2018 Author Share Posted August 16, 2018 Engine build is going ok, crank was toast from all the debris and all the exhaust valves were bent but no surprise there, currently being balanced :-) Link to comment Share on other sites More sharing options...
RedRooster Posted October 24, 2018 Author Share Posted October 24, 2018 Quite pleased with the build, good flat torque curve, Link to comment Share on other sites More sharing options...
Nick Jones Posted October 24, 2018 Share Posted October 24, 2018 Should be nice to drive. What was the final spec? Nick Link to comment Share on other sites More sharing options...
RedRooster Posted October 24, 2018 Author Share Posted October 24, 2018 Mostly stock 2 litre, apart from the TR5 cam, roller rockers & dizzy curve. Link to comment Share on other sites More sharing options...
Nick Jones Posted October 24, 2018 Share Posted October 24, 2018 On 40 Webbers? Pheonix 6-3-1? Peak torque is a long way up...... but nice and flat. Nick Link to comment Share on other sites More sharing options...
RedRooster Posted October 24, 2018 Author Share Posted October 24, 2018 Yeah and those bits. Not much difference in torque from 2500 all the way up. Link to comment Share on other sites More sharing options...
Bumblebee Posted October 24, 2018 Share Posted October 24, 2018 So your build is kind of the same as mine but with a slightly different cam , you have roller rockers, and mines had some head work and is megajolted. They are much of a muchness to be honest Mine made peak torque at 5000rpm (123lbft) . It went over 110lbft at 2500rpm and over 120 at about 4300 rpm and was still over 120 when we shut off at 5500. so give or take a handfull they are there or thereabouts. I am running a single bore pipe on a 6-3-1 phoenix fits where it touches manifold and triple 40s too, with an electric fan So in the grand scheme of things they are more or less identical curves coming in at about 2500 and slowly coming up till 5000 (ish), just little differences here and there. Good news for you after the piston incident. Touch wood it will all be fine now. Link to comment Share on other sites More sharing options...
RedRooster Posted October 24, 2018 Author Share Posted October 24, 2018 I hope so, i'll take reliability over the last few BHP's any day. Having the engine set up on the dyno is money well spent in my opinion, carbs are tuned in & the dizzy curve has been modified to suit. Torque looks flat so she should pull well all the way through the rev range. Link to comment Share on other sites More sharing options...
Bumblebee Posted October 24, 2018 Share Posted October 24, 2018 Well assuming it pulls the same way mine does, it will be a grin a minute. I love getting to that bit, the one you really cant quite put your finger on , when the cam gets excited, the back of the car sits itself down and things go into hyperdrive,** and it makes a noisy howl like a rather disgruntled wild animal **To be honest my eurobox Audi is quicker, but it feels much faster when your bum is 4 inches from the floor! Link to comment Share on other sites More sharing options...
RedRooster Posted October 24, 2018 Author Share Posted October 24, 2018 Oh yes i know what you mean & the gearing makes it take off like a scolded cat, can't wait to get the engine back :-) Link to comment Share on other sites More sharing options...
Nick Jones Posted October 24, 2018 Share Posted October 24, 2018 So that's a dyno curve rather than rolling road......? N Link to comment Share on other sites More sharing options...
RedRooster Posted October 24, 2018 Author Share Posted October 24, 2018 If that was RR figures i'd have the most powerful 2L GT6 ever. Link to comment Share on other sites More sharing options...
RedRooster Posted November 27, 2018 Author Share Posted November 27, 2018 Now that's a thing of rare joy and beauty, going to have to wait a few weeks before I get to slot it back in the car though. Link to comment Share on other sites More sharing options...
RedRooster Posted November 27, 2018 Author Share Posted November 27, 2018 (edited) While I was waiting for the van man, added sounddeafening to the gearbox tunnel, good stuff but I should have practiced on a flat panel first. Edited November 27, 2018 by RedRooster Spelling Link to comment Share on other sites More sharing options...
Nick Jones Posted November 27, 2018 Share Posted November 27, 2018 Blimey, that’s well wrapped. I usually put it on the underside. Engine looks eager to go in to me! Link to comment Share on other sites More sharing options...
RedRooster Posted January 7, 2019 Author Share Posted January 7, 2019 New engines just back in, nothing connected up yet just in the engine mounts, but good to see the engine back in place. RR Link to comment Share on other sites More sharing options...
RedRooster Posted January 9, 2019 Author Share Posted January 9, 2019 Went to connect up the prop shaft and not 20 seconds in the car and the gear box remote housing cut me badly the bastard. Talking of which getting the exhaust back in and connected up to the tubular manifold was much of a similar vein, for give me the pun. Need to touch up the chassis rails now the zorst is back in, another job... RR Link to comment Share on other sites More sharing options...
Nick Jones Posted January 9, 2019 Share Posted January 9, 2019 Blood sacrifice is often required to appease the gods...... Link to comment Share on other sites More sharing options...
RedRooster Posted January 14, 2019 Author Share Posted January 14, 2019 Looks like I've lost the engine number after the block was decked, not a problem for me but could be here with registering it, does anyone know where to get the right sized stamps? Measured my old block and they look to be 9/16 which is roughly 7mm and not a size readily available. Link to comment Share on other sites More sharing options...
Nick Jones Posted January 14, 2019 Share Posted January 14, 2019 9/16..... (14mm) or 5/16, which is more like 8mm...... I suspect the latter? Axminster Tools seem to have a fair selection though gets a bit pricey for one time use! Vitesse engine is also blank for the same reason..... Link to comment Share on other sites More sharing options...
