yorkshire_spam
Spitfire Diff Bearings (1500)
I've been concerned about the quality of some of the unbranded bearings being sold for diff and gearbox rebuilds, so I tracked down equivalent part numbers and sourced mine from reputable bearing factors.
These are based on the Triumph part numbers for my Spitfire 1500 with 3.63:1 ratio.
BTB440 - pinion outer.  (Listed as an alternative to 134070)
Timken Part Number M84548 - M84510
1”x2.25 (2 ¼)x0.765 (49/64”)
134065 - pinion inner
Timken Part Number M88040 - M88010
1.1250” (1 ⅛”)  x 2.6875 (2 11/16) x 0.8750” (7/8)
28.575mm x 68.263mm x 22.225
Diff Carrier
GHB105 - diff carrier (to commission number FH106101)
LM67048 - LM67010 (TBC!)
(31.75x59.13x15.88mm)
UKC4805 - diff carrier (from commission number FH106102)
Timken Part Number  L68149 - L68110  (TIMKEN set-13? might be the same, it has the same dimensions?)
1.3775“ x 2.3280” x 0.6250”
(34.99x59.13x15.88mm)
Not as hard to find, but included for reference:
533360A/128572 Inner axle shaft (output shaft) bearing
bearing part number 6205 C3 clearance
 25 x 52 x 15mm
Please treat with caution! I'm in the middle of rebuilding my Spit diff with the bearings listed above, everything seems to fit just fine, but there's a chance I made a mistake!
Updated again based on some more research - I'll try and confirm more ASAP
Edited by yorkshire_spam
Additional information
.... please take care that the output shaft bearing should be with C3 clearance.
For the diff carrier I have the SKF numbers 67048 and 67010
Martin
Thanks for the info but 4.11 diff or 3.89/3.63/3.27? The 4.11 has some differences from the others...... and there are at least two variants of it.
Thanks for the comments guys, I've updated the original post to reflect. Provided the Triumph part number marries up they should be ok for other diffs. If it's considered useful I'll try and expand the list for other diff bearings?
@Martin I'll check those SKF numbers against the Timken ones I have - thanks!
Thanks for that - especially since I've got a couple of 3.63s here, including the one in my car which, after about 45k fairly hard miles, is beginning to cry!
Care needs to be taken with the carrier bearings as well though, I've noticed that the Triumph part number changes at a specific commission number. What I'll try and do when I have some time is add the ones for part numbers other than the ones for my diff, so we have a complete set to refer to. Martin has me a bit worried with those SKF part numbers as they are not listed as equivalent to the timken ones I have, so I'm wondering if they correspond to the earlier ones. (Or if I've got the wrong ones?! They do seem to fit well though!)
I'm pretty sure the references that @Martin has are for the earlier carrier bearings corresponding to p/n GHB105
I'm going to cross check the p/n used in other diffs and see if they are common.
