lotus62
gt6 vert.link dimensions
Hi all, does anybody know the dimensions from a gt6 upright? measured from the outsite of the brake face.
going to make my own vert.links to fit into the 13" steel wheels with disc brake's so need a bit of information just to see if I can be done.
(I allready have volvo lobro's,  r100 short shafts and mgf uprights)
Thanks, Rick
thanks, I have this one allready (much worser than this one btw) , missing a few important dimensions unfortunately
Rick
Fabricating your own is quite an ambition!
MGF uprights come with their own discs.     Cutting off the top of the uprright and bolting a piece of Steel tube to take the spring eye did it for me, but it did need fabricated wishbones.
Hub flange outer face to backplate mounting face is 45.65mm.  Just lacking the centre line position now. Only assembled units I have at the moments are on cars so not very easy to measure accurately.
John, how often do you need to replace the rose joint? (rod end) i would like to have rubber bushes but the mgf upright is too wide at the bottom. also I like the holes to be in line to make the A-arm easier to fabricate and on the mgf they seem to have a big offset
Rick
I may have those dimensions documented, I'll look when I get home.  If you have Autocad you may be able to take it from a good DWG I have.  I'll look
Hi Steve looking forward to them...  unfortunately I do not have autocad, but if it is the only way to get them I'll visit a customer with the .dwg file as they have autocad
thanks, Rick
Hi Rick - welcome to the forum
After a struggle to kick my laptop into submission (thinks it's still xmas!!!)
Dimensions requested are
A 106.52
B 122.23
C 110.17
D 86.98
I have a fully drawn up 2D model on CAD if you require any other dims shout:biggrin:
Dave
Rick
Sorry missed tbis q until now.  I rebuild every year, using sphericals that cost about £10 each.   Not bank breaking.
thanks, Rick
Plenty of free downloadable DWG readers out there.  You won't be able to change anything but you will be able to see it fine.  Some of them even allow you get dimensions.
John, thanks for the answer, bur a rebuild every year is out of the question (I also have an europa and an esprit competing for attention :biggrin: )
Nick, I have seen them before but only after reading your reply I remembered it.
I am clearing out the garages at the moment just to get some space to work, my god how much shit you collect over the years.  already 3 trips to the waste collectors/recycling points this week.
Replacing roe joints is hardly a rebuild!.
Needs the geometry checking, but like replacing track rod ends, if you count the umber of turn it'll be bob-on when you do!
